Lenovo G500S Touch Disc Drive Replacement
  1. Lenovo G500S Touch Disc Drive Replacement, Battery: step 1, image 1 of 3 Lenovo G500S Touch Disc Drive Replacement, Battery: step 1, image 2 of 3 Lenovo G500S Touch Disc Drive Replacement, Battery: step 1, image 3 of 3
    • Make sure that your device is powered off and unplugged from the power source.
    • Flip your device over so that the back is facing you.
    • Using your fingers, push the tabs in opposite directions to eject the battery.
    • Remove the battery from the device.
    Ask FixBot
  2. Lenovo G500S Touch Disc Drive Replacement, Back Panel: step 2, image 1 of 2 Lenovo G500S Touch Disc Drive Replacement, Back Panel: step 2, image 2 of 2
    • Remove the three 4mm screws on the back cover using the Phillips #00 screwdriver.
    • Remove the back cover from the device.
    Ask FixBot
  3. Lenovo G500S Touch Disc Drive Replacement, Disc Drive: step 3, image 1 of 3 Lenovo G500S Touch Disc Drive Replacement, Disc Drive: step 3, image 2 of 3 Lenovo G500S Touch Disc Drive Replacement, Disc Drive: step 3, image 3 of 3
    • Remove the single 6mm screw holding the disc drive in place using the same screwdriver.
    • Carefully pull out the disc drive and remove it from the device.
    Ask FixBot
2 other people completed this guide.
Christopher Foster
512 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 17
All Time: 1,272
