Lenovo G50-80 80E5 RAM Replacement
  1. Lenovo G50-80 80E5 RAM Replacement, Battery: step 1, image 1 of 1
    • Place the laptop on a flat surface with the back cover facing up and the hinges facing you.
    Ask FixBot
  2. Lenovo G50-80 80E5 RAM Replacement: step 2, image 1 of 3 Lenovo G50-80 80E5 RAM Replacement: step 2, image 2 of 3 Lenovo G50-80 80E5 RAM Replacement: step 2, image 3 of 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
    Ask FixBot
  3. Lenovo G50-80 80E5 RAM Replacement: step 3, image 1 of 3 Lenovo G50-80 80E5 RAM Replacement: step 3, image 2 of 3 Lenovo G50-80 80E5 RAM Replacement: step 3, image 3 of 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
    Ask FixBot
  4. Lenovo G50-80 80E5 RAM Replacement: step 4, image 1 of 3 Lenovo G50-80 80E5 RAM Replacement: step 4, image 2 of 3 Lenovo G50-80 80E5 RAM Replacement: step 4, image 3 of 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
    Ask FixBot
  5. Lenovo G50-80 80E5 RAM Replacement, Bottom Access Panel: step 5, image 1 of 2 Lenovo G50-80 80E5 RAM Replacement, Bottom Access Panel: step 5, image 2 of 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
    Ask FixBot
  6. Lenovo G50-80 80E5 RAM Replacement: step 6, image 1 of 2 Lenovo G50-80 80E5 RAM Replacement: step 6, image 2 of 2
    • Slide the cover away from the hinges and lift the panel off.
    Ask FixBot
  7. Lenovo G50-80 80E5 RAM Replacement, RAM: step 7, image 1 of 2 Lenovo G50-80 80E5 RAM Replacement, RAM: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to push the two silver clips to the left and right of the RAM chip outwards.
    • The RAM will release after pushing the second clip.
    Ask FixBot
  8. Lenovo G50-80 80E5 RAM Replacement: step 8, image 1 of 1
    • Use your fingers to carefully remove the RAM chip by sliding it out at a ~45° angle.
    Ask FixBot
2 other people completed this guide.
1 Guide Comment
Kun je ook meer dan 4GB toevoegen als je beide RAM chips vervangt. Bijvoorbeeld 2x 8GB.
Freek Bosveld - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 48
All Time: 2,214
