Lenovo G50-70 Screen Replacement
    1. Lenovo G50-70 Screen Replacement, Screen: step 1, image 1 of 3 Lenovo G50-70 Screen Replacement, Screen: step 1, image 2 of 3 Lenovo G50-70 Screen Replacement, Screen: step 1, image 3 of 3
      • Push the switches outwards to release the battery.
      • It is important to remove the battery in order to avoid the laptop from turning on and avoiding any electrical issues.
      Ask FixBot
    2. Lenovo G50-70 Screen Replacement: step 2, image 1 of 3 Lenovo G50-70 Screen Replacement: step 2, image 2 of 3 Lenovo G50-70 Screen Replacement: step 2, image 3 of 3
      • Use a flat head screwdriver (or a plastic opening tool) to pop off the screen bezel/ plastic cover.
      • Once one side comes off you can use your hands to pull the rest of the plastic cover off; it shouldn't take much force to remove it from the device.
      Ask FixBot
    3. Lenovo G50-70 Screen Replacement: step 3, image 1 of 3 Lenovo G50-70 Screen Replacement: step 3, image 2 of 3 Lenovo G50-70 Screen Replacement: step 3, image 3 of 3
      • After removing the plastic cover, gently tilt and lift the screen, but do not remove it from the device.
      Ask FixBot
    4. Lenovo G50-70 Screen Replacement: step 4, image 1 of 3 Lenovo G50-70 Screen Replacement: step 4, image 2 of 3 Lenovo G50-70 Screen Replacement: step 4, image 3 of 3
      • Using a Phillips #00 screwdriver, remove four 3.5 mm screws at the top right and left side of the screen.
      Ask FixBot
    5. Lenovo G50-70 Screen Replacement: step 5, image 1 of 3 Lenovo G50-70 Screen Replacement: step 5, image 2 of 3 Lenovo G50-70 Screen Replacement: step 5, image 3 of 3
      • Using the same Phillips #00 screwdriver, remove the four 3.5 mm screws at the bottom of the screen.
      Ask FixBot
    6. Lenovo G50-70 Screen Replacement: step 6, image 1 of 3 Lenovo G50-70 Screen Replacement: step 6, image 2 of 3 Lenovo G50-70 Screen Replacement: step 6, image 3 of 3
      • Once the screen is loose and can be moved around, make sure to readjust the laptop gently.
      • Lay the screen flat on the keyboard in order to make it easier to find the connector.
      Ask FixBot
    7. Lenovo G50-70 Screen Replacement: step 7, image 1 of 3 Lenovo G50-70 Screen Replacement: step 7, image 2 of 3 Lenovo G50-70 Screen Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Using a pair of tweezers, peel the sticker to off of the device.
      Ask FixBot
    8. Lenovo G50-70 Screen Replacement: step 8, image 1 of 3 Lenovo G50-70 Screen Replacement: step 8, image 2 of 3 Lenovo G50-70 Screen Replacement: step 8, image 3 of 3
      • Carefully disconnect the display cable from the rest of the screen.
      Ask FixBot
    9. Lenovo G50-70 Screen Replacement: step 9, image 1 of 1
      • Remove the screen from the device.
      Ask FixBot
3 other people completed this guide.
Brandon Navas
241 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 142
All Time: 3,082
