Lenovo G50-70 Fan Replacement
  1. Lenovo G50-70 Fan Replacement, Battery: step 1, image 1 of 3 Lenovo G50-70 Fan Replacement, Battery: step 1, image 2 of 3 Lenovo G50-70 Fan Replacement, Battery: step 1, image 3 of 3
    • Push the left switch (labeled 1) to the left to show red underneath. This will unlock battery.
    • Push the right switch (labeled 2) to the right. This will eject battery.
    Ask FixBot
  2. Lenovo G50-70 Fan Replacement: step 2, image 1 of 1
    • Rotate the battery away from the laptop.
    Ask FixBot
  3. Lenovo G50-70 Fan Replacement, Back Access Panel: step 3, image 1 of 2 Lenovo G50-70 Fan Replacement, Back Access Panel: step 3, image 2 of 2
    • Remove the three 6mm Phillips #0 screws holding the back access panel on.
    Ask FixBot
  4. Lenovo G50-70 Fan Replacement: step 4, image 1 of 2 Lenovo G50-70 Fan Replacement: step 4, image 2 of 2
    • Slide the cover toward you to unlatch it.
    • The edge of the panel will slide away from the laptop so it can be lifted.
    Ask FixBot
  5. Lenovo G50-70 Fan Replacement, Fan: step 5, image 1 of 2 Lenovo G50-70 Fan Replacement, Fan: step 5, image 2 of 2
    • Remove the three 6mm Phillips #0 screws on the perimeter of the fan.
    Ask FixBot
  6. Lenovo G50-70 Fan Replacement: step 6, image 1 of 2 Lenovo G50-70 Fan Replacement: step 6, image 2 of 2
    • The fan is plugged into the motherboard next to the copper heat sync.
    • Unplug the bundled wire connector by pulling up on the white plug.
    • Do not pull up by the wires.
    Ask FixBot
  7. Lenovo G50-70 Fan Replacement: step 7, image 1 of 2 Lenovo G50-70 Fan Replacement: step 7, image 2 of 2
    • Lift fan out of case.
    Ask FixBot
8 other people completed this guide.
1 Guide Comment
can it take a .5 amp fan??
Basil Jabir - Reply Share
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 39
All Time: 2,818
