Lenovo Flex 3-1120 Network Card Replacement
    1. Lenovo Flex 3-1120 Network Card Replacement, Bottom Panel: step 1, image 1 of 1
      • Lay the computer down with the bottom panel facing up.
      Ask FixBot
    2. Lenovo Flex 3-1120 Network Card Replacement: step 2, image 1 of 2 Lenovo Flex 3-1120 Network Card Replacement: step 2, image 2 of 2
      • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
      • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
      Ask FixBot
    3. Lenovo Flex 3-1120 Network Card Replacement: step 3, image 1 of 1
      • Wedge the plastic opening tool into the small space under the back panel.
      • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
      • Slide the tool along the edges of the computer until the bottom panel is completely separated.
      • You may start prying the bottom panel on any edge.
      Ask FixBot
    4. Lenovo Flex 3-1120 Network Card Replacement: step 4, image 1 of 1
      • Lift the bottom panel off of the computer.
      Ask FixBot
    1. Lenovo Flex 3-1120 Network Card Replacement, Network Card: step 5, image 1 of 1
      • Locate the network card on the top right of the computer.
      Ask FixBot
    2. Lenovo Flex 3-1120 Network Card Replacement: step 6, image 1 of 2 Lenovo Flex 3-1120 Network Card Replacement: step 6, image 2 of 2
      • Locate the single 3.5mm Phillips head screw on the right edge of the network card.
      • Remove the single screw with a size 0 Phillips screwdriver.
      Ask FixBot
    3. Lenovo Flex 3-1120 Network Card Replacement: step 7, image 1 of 1
      • Slide the network card out to the right to remove it from the motherboard.
      Ask FixBot
    4. Lenovo Flex 3-1120 Network Card Replacement: step 8, image 1 of 2 Lenovo Flex 3-1120 Network Card Replacement: step 8, image 2 of 2
      • Locate the black and white antenna wires that are connected to the right edge of the network card.
      • Wiggle and pull upward on the two antenna cords connecting to the card to remove them.
      Ask FixBot
Geoff Bentz
961 Reputation
5 Guides authored
1 Guide Comment
Where can I buy a replacement card? Can I replace the AC-3160 with the newer 7265D card?
barence321 - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 24
All Time: 1,149
