Lenovo Flex 2-15 Keyboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
74
All Time:
479
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This guide helps you replace the Lenovo Flex 2-15 keyboard. You might need to replace your keyboard when the keys start to stick or some keys no longer functions. The keyboard is one of most important part of the computer because It handles most of the human interface.
Tools
    1. Lenovo Flex 2-15 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Begin by taking the back plate off of your device. Using a Phillips head screw driver, take out the highlighted screws for your device.
      Ask FixBot
    2. Lenovo Flex 2-15 Keyboard Replacement: step 2, image 1 of 1
      • Remove battery from the motherboard by unplugging the cord and removing the screws.
      Ask FixBot
    3. Lenovo Flex 2-15 Keyboard Replacement: step 3, image 1 of 1
      • Once you have the battery removed, locate the cable for your new battery and connect it on the same port from your old battery. Secure it onto the laptop by using the screws. After this step is complete, complete step 1 in reverse order to secure the plate cover over your motherboard.
      Ask FixBot
    1. Lenovo Flex 2-15 Keyboard Replacement, Keyboard: step 4, image 1 of 2 Lenovo Flex 2-15 Keyboard Replacement, Keyboard: step 4, image 2 of 2
      • Apply gentle pressure with the Philips #00 screwdriver through the hole to pop out the keyboard.
      • The hole in the red circle is a through hole to the back of keyboard. If pressure is applied the keyboard will pop off.
      Ask FixBot
    2. Lenovo Flex 2-15 Keyboard Replacement: step 5, image 1 of 1
      • Lift up the keyboard with your fingers.
      Ask FixBot
    3. Lenovo Flex 2-15 Keyboard Replacement: step 6, image 1 of 1
      • Flip up the black ZIF locking flap that secures the keyboard ribbon cable.
      • Disconnect the ribbon cable.
      • Remove the keyboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 74
All Time: 479
