Lenovo Essential G570 Fan Replacement
    1. Lenovo Essential G570 Fan Replacement, Battery: step 1, image 1 of 1
      • Turn off the laptop.
      • Disconnect the charging cable.
      • Failure to unplug the cable could result in electric shock.
      • Turn the computer upside down.
      Ask FixBot
    2. Lenovo Essential G570 Fan Replacement: step 2, image 1 of 2 Lenovo Essential G570 Fan Replacement: step 2, image 2 of 2
      • Locate the two switches that lock the battery.
      • Push the right switch outwards to unlock the battery.
      Ask FixBot
    3. Lenovo Essential G570 Fan Replacement: step 3, image 1 of 2 Lenovo Essential G570 Fan Replacement: step 3, image 2 of 2
      • Push and hold the left switch outwards to unlock the battery.
      • Pull the battery away from the computer.
      Ask FixBot
    1. Lenovo Essential G570 Fan Replacement, Back Panel: step 4, image 1 of 1
      • Turn the laptop over so that the bottom side is facing up.
      Ask FixBot
    2. Lenovo Essential G570 Fan Replacement: step 5, image 1 of 1
      • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
      • The screws do not come out fully from the back plate. They stay attached to the plate itself.
      Ask FixBot
    3. Lenovo Essential G570 Fan Replacement: step 6, image 1 of 3 Lenovo Essential G570 Fan Replacement: step 6, image 2 of 3 Lenovo Essential G570 Fan Replacement: step 6, image 3 of 3
      • With the screws removed, insert the plastic opening tool into the groove located on the right side.
      • Begin to pry up, and the plate should lift up from the body of the laptop.
      • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
      Ask FixBot
    1. Lenovo Essential G570 Fan Replacement, Fan: step 7, image 1 of 2 Lenovo Essential G570 Fan Replacement, Fan: step 7, image 2 of 2
      • Carefully pull the fan's power connector from the laptop.
      Ask FixBot
    2. Lenovo Essential G570 Fan Replacement: step 8, image 1 of 2 Lenovo Essential G570 Fan Replacement: step 8, image 2 of 2
      • Remove the three 5mm Phillips #1 screws holding the fan in place.
      Ask FixBot
    3. Lenovo Essential G570 Fan Replacement: step 9, image 1 of 2 Lenovo Essential G570 Fan Replacement: step 9, image 2 of 2
      • Remove the fan by pulling it up and away from the computer.
      Ask FixBot
2 other people completed this guide.
Lucio
235 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 76
All Time: 1,084
