Lenovo Essential G560 Hard Drive Replacement
Views: 23K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
110
All Time:
23,314
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The hard drive is likely to malfunction when dropped or put under a lot of stress. If the computer won't boot and is having hard disk/hard drive reading errors, follow this guide to replace it.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Lenovo Essential G560 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the cable could result in electric shock.
      • Flip the computer upside down.
      Ask FixBot
    2. Lenovo Essential G560 Hard Drive Replacement: step 2, image 1 of 2 Lenovo Essential G560 Hard Drive Replacement: step 2, image 2 of 2
      • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
      Ask FixBot
    3. Lenovo Essential G560 Hard Drive Replacement: step 3, image 1 of 1
      • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
      Ask FixBot
    1. Lenovo Essential G560 Hard Drive Replacement, Back Panel: step 4, image 1 of 1
      • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
      Ask FixBot
    2. Lenovo Essential G560 Hard Drive Replacement: step 5, image 1 of 2 Lenovo Essential G560 Hard Drive Replacement: step 5, image 2 of 2
      • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
      • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
      Ask FixBot
    3. Lenovo Essential G560 Hard Drive Replacement: step 6, image 1 of 1
      • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
      Ask FixBot
    1. Lenovo Essential G560 Hard Drive Replacement, Hard Drive: step 7, image 1 of 1
      • Remove the two 5.33 mm Phillips #1 screws holding the hard drive in place.
      • Be careful with these screws, as they can be stripped or lost easily.
      Ask FixBot
    2. Lenovo Essential G560 Hard Drive Replacement: step 8, image 1 of 1
      • To remove the hard drive from the computer, grab the black tab attached to the hard drive and pull the tab downwards toward the bottom of the laptop.
      • When installing the hard drive, make sure the hard drive label faces down.
      Ask FixBot
    3. Lenovo Essential G560 Hard Drive Replacement: step 9, image 1 of 1
      • Unscrew the four 5.2 mm Phillips #1 screws. There are two on each side of the drive holding it in the drive bay.
      Ask FixBot
    4. Lenovo Essential G560 Hard Drive Replacement: step 10, image 1 of 1
      • Pull the drive out of the bay. If all the screws were removed correctly, it should simply slide out.
      Ask FixBot
9 other people completed this guide.
Dennis Wong
618 Reputation
5 Guides authored
Cal Poly, Team 18-40, Regan Winter 2013 Member of Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Members
84 Guides authored
2 Guide Comments
In step 1, failure to unplug the cable does not result in electric shock. The power supply voltage is too low for such shock to happen to a human, but it can cause electrical damage to the motherboard. It is always a safe procedure to work on any machine unpowered (both power supply and battery disconnected and/or removed).
In step 9, be sure to remember the direction that the original drive was pointing when removing. The new drive must point the same direction.
rayramirez - Reply Share
In Step 3 - after removing the battery, press & hold the power buttton for 5 seconds to discharge any residual power in the circuitry before moving on to Step 4.
Iain - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 110
All Time: 23,314
