Up to 20% off select tools
Lenovo Essential B570 RAM Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
112
All Time:
1,645
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will help you remove and replace your RAM.
    1. Lenovo Essential B570 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn over laptop.
      • Switch open the left battery lock.
      • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
      Ask FixBot
    2. Lenovo Essential B570 RAM Replacement: step 2, image 1 of 1
      • Hold the right battery lock open with one hand while removing the battery itself with the other.
      Ask FixBot
    1. Lenovo Essential B570 RAM Replacement, Back Panel: step 3, image 1 of 1
      • Loosen the five Philips screws that secure the panel.
      • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
      Ask FixBot
    2. Lenovo Essential B570 RAM Replacement: step 4, image 1 of 3 Lenovo Essential B570 RAM Replacement: step 4, image 2 of 3 Lenovo Essential B570 RAM Replacement: step 4, image 3 of 3
      • Prop open the cover with a plastic opening tool.
      • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
      Ask FixBot
    1. Lenovo Essential B570 RAM Replacement, RAM: step 5, image 1 of 2 Lenovo Essential B570 RAM Replacement, RAM: step 5, image 2 of 2
      • Release your RAM by pulling its locks away from one another.
      Ask FixBot
    2. Lenovo Essential B570 RAM Replacement: step 6, image 1 of 2 Lenovo Essential B570 RAM Replacement: step 6, image 2 of 2
      • Remove RAM by carefully pulling it away from its socket.
      Ask FixBot
Author
with
Samuel Filliettaz
900 Reputation
5 Guides authored
UMass Dartmouth, Team 4-5, Catania Fall 2015 Member of UMass Dartmouth, Team 4-5, Catania Fall 2015
UMASSD-CATANIA-F15S4G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 112
All Time: 1,645
