Lenovo Essential B570 Hard Drive Replacement
Views: 5.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
99
All Time:
5,608
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show how to be able to identify and remove your Hard Drive using common tools.
Tools
    1. Lenovo Essential B570 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Turn over laptop.
      • Switch open the left battery lock.
      • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
      Ask FixBot
    2. Lenovo Essential B570 Hard Drive Replacement: step 2, image 1 of 1
      • Hold the right battery lock open with one hand while removing the battery itself with the other.
      Ask FixBot
    1. Lenovo Essential B570 Hard Drive Replacement, Back Panel: step 3, image 1 of 1
      • Loosen the five Philips screws that secure the panel.
      • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
      Ask FixBot
    2. Lenovo Essential B570 Hard Drive Replacement: step 4, image 1 of 3 Lenovo Essential B570 Hard Drive Replacement: step 4, image 2 of 3 Lenovo Essential B570 Hard Drive Replacement: step 4, image 3 of 3
      • Prop open the cover with a plastic opening tool.
      • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
      Ask FixBot
    1. Lenovo Essential B570 Hard Drive Replacement, Hard Drive: step 5, image 1 of 3 Lenovo Essential B570 Hard Drive Replacement, Hard Drive: step 5, image 2 of 3 Lenovo Essential B570 Hard Drive Replacement, Hard Drive: step 5, image 3 of 3
      • Pull the Hard Drive out of its socket.
      • Lift the tab upwards to remove the hard drive.
      • If you cannot pull the hard drive out of its socket, there is a possibility that there is a 4mm Phillips #1 screw securing it. Locate it and remove it before continuing. It is in very close proximity to the black tab.
      Ask FixBot
3 other people completed this guide.
Samuel Filliettaz
900 Reputation
5 Guides authored
UMass Dartmouth, Team 4-5, Catania Fall 2015 Member of UMass Dartmouth, Team 4-5, Catania Fall 2015
UMASSD-CATANIA-F15S4G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 99
All Time: 5,608
