Lenovo Edge Thinkpad E431 Screen Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
35
Past 30 Days:
88
All Time:
2,258
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the screen on a Lenovo ThinkPad Edge E431 laptop.
Parts
Tools
    1. Lenovo Edge Thinkpad E431 Screen Replacement, Battery: step 1, image 1 of 2 Lenovo Edge Thinkpad E431 Screen Replacement, Battery: step 1, image 2 of 2
      • Remove the 2mm Phillips #00 screw from the battery cover.
      • Lift the battery cover out of its slot.
      Ask FixBot
    2. Lenovo Edge Thinkpad E431 Screen Replacement: step 2, image 1 of 1
      • Disconnect the battery cable.
      Ask FixBot
    1. Lenovo Edge Thinkpad E431 Screen Replacement, Screen: step 3, image 1 of 1
      • Use the pointed end of a spudger to remove the two screw covers from the bottom corners of the display.
      Ask FixBot
    2. Lenovo Edge Thinkpad E431 Screen Replacement: step 4, image 1 of 1
      • Remove the two 2mm Phillips #00 screws found at the bottom corners of the display.
      Ask FixBot
    3. Lenovo Edge Thinkpad E431 Screen Replacement: step 5, image 1 of 1
      • Separate the front bezel from the display using the plastic opening tool.
      Ask FixBot
    4. Lenovo Edge Thinkpad E431 Screen Replacement: step 6, image 1 of 1
      • Remove the four 2mm Phillips #00 screws from the screen.
      Ask FixBot
    5. Lenovo Edge Thinkpad E431 Screen Replacement: step 7, image 1 of 2 Lenovo Edge Thinkpad E431 Screen Replacement: step 7, image 2 of 2
      • Lay the screen flat on top of the keyboard.
      Ask FixBot
    6. Lenovo Edge Thinkpad E431 Screen Replacement: step 8, image 1 of 2 Lenovo Edge Thinkpad E431 Screen Replacement: step 8, image 2 of 2
      • Peel up the adhesive tape to unlatch the metal retaining bracket on the display cable.
      Ask FixBot
3 other people completed this guide.
USF Tampa, Team S3-G3, Nance Spring 2018 Member of USF Tampa, Team S3-G3, Nance Spring 2018
USFT-NANCE-S18S3G3
4 Members
72 Guides authored
1 Guide Comment
Where do I buy the screen
Link - Reply Share
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 88
All Time: 2,258
