Lenovo Edge 2-1580 RAM Replacement
    1. Lenovo Edge 2-1580 RAM Replacement, Battery: step 1, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement, Battery: step 1, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
      Ask FixBot
    2. Lenovo Edge 2-1580 RAM Replacement: step 2, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement: step 2, image 2 of 2
      • Using a plastic opening tool, pull out the back panel from the laptop.
      Ask FixBot
    3. Lenovo Edge 2-1580 RAM Replacement: step 3, image 1 of 3 Lenovo Edge 2-1580 RAM Replacement: step 3, image 2 of 3 Lenovo Edge 2-1580 RAM Replacement: step 3, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
      • Disconnect the battery connector from the motherboard.
      Ask FixBot
    4. Lenovo Edge 2-1580 RAM Replacement: step 4, image 1 of 1
      • Pull the battery outward and remove it from the rest of the laptop.
      Ask FixBot
    1. Lenovo Edge 2-1580 RAM Replacement, RAM: step 5, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement, RAM: step 5, image 2 of 2
      • Remove the metallic RAM cover
      Ask FixBot
    2. Lenovo Edge 2-1580 RAM Replacement: step 6, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement: step 6, image 2 of 2
      • With both of your thumbs, gently pull both adjacent levers outwards. The RAM module will rise a bit.
      Ask FixBot
    3. Lenovo Edge 2-1580 RAM Replacement: step 7, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement: step 7, image 2 of 2
      • Grab the RAM module , and gently pull it out.
      Ask FixBot
Julian Escallon
735 Reputation
5 Guides authored
USF Tampa, Team S14-G1, Boczar Fall 2017 Member of USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 Members
60 Guides authored
2 Guide Comments
What is the Max ram for this, and Can you do one where you replace the screen?
Gary Mike - Reply Share
but how exactly do i open the cover?
Jestem Bo tak - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 110
All Time: 2,517
