Lenovo Edge 2-1580 Fan Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
91
All Time:
1,212
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to remove and replace the fan cooling solution of the laptop if for some reason it has become faulty and needs replacement.
Tools
    1. Lenovo Edge 2-1580 Fan Replacement, Battery: step 1, image 1 of 2 Lenovo Edge 2-1580 Fan Replacement, Battery: step 1, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
      Ask FixBot
    2. Lenovo Edge 2-1580 Fan Replacement: step 2, image 1 of 2 Lenovo Edge 2-1580 Fan Replacement: step 2, image 2 of 2
      • Using a plastic opening tool, pull out the back panel from the laptop.
      Ask FixBot
    3. Lenovo Edge 2-1580 Fan Replacement: step 3, image 1 of 3 Lenovo Edge 2-1580 Fan Replacement: step 3, image 2 of 3 Lenovo Edge 2-1580 Fan Replacement: step 3, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
      • Disconnect the battery connector from the motherboard.
      Ask FixBot
    4. Lenovo Edge 2-1580 Fan Replacement: step 4, image 1 of 1
      • Pull the battery outward and remove it from the rest of the laptop.
      Ask FixBot
    1. Lenovo Edge 2-1580 Fan Replacement, Fan: step 5, image 1 of 3 Lenovo Edge 2-1580 Fan Replacement, Fan: step 5, image 2 of 3 Lenovo Edge 2-1580 Fan Replacement, Fan: step 5, image 3 of 3
      • Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
      • The network card will pop up by itself.
      Ask FixBot
    2. Lenovo Edge 2-1580 Fan Replacement: step 6, image 1 of 2 Lenovo Edge 2-1580 Fan Replacement: step 6, image 2 of 2
      • Grab the network card and gently pull it out.
      Ask FixBot
    3. Lenovo Edge 2-1580 Fan Replacement: step 7, image 1 of 2 Lenovo Edge 2-1580 Fan Replacement: step 7, image 2 of 2
      • Pull out the RAM metallic cover.
      Ask FixBot
    4. Lenovo Edge 2-1580 Fan Replacement: step 8, image 1 of 2 Lenovo Edge 2-1580 Fan Replacement: step 8, image 2 of 2
      • Grab the black insulating tape and pull it out.
      Ask FixBot
    5. Lenovo Edge 2-1580 Fan Replacement: step 9, image 1 of 2 Lenovo Edge 2-1580 Fan Replacement: step 9, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
      • (5) Five copper and (1) one silver Phillips #0 5.4mm screws.
      • Disconnect the fan from the motherboard.
      Ask FixBot
    6. Lenovo Edge 2-1580 Fan Replacement: step 10, image 1 of 2 Lenovo Edge 2-1580 Fan Replacement: step 10, image 2 of 2
      • Unplug the Fan connector from its socket on the motherboard.
      Ask FixBot
    7. Lenovo Edge 2-1580 Fan Replacement: step 11, image 1 of 2 Lenovo Edge 2-1580 Fan Replacement: step 11, image 2 of 2
      • Carefully remove the fan from the laptop.
      Ask FixBot
Julian Escallon
735 Reputation
5 Guides authored
USF Tampa, Team S14-G1, Boczar Fall 2017 Member of USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 Members
60 Guides authored
2 Guide Comments
Looks like heat sink and fan are one unit. Advice for regular dust cleaning? How was the condition of the factory thermal paste?
cfryhover - Reply Share
Where can one find this fan?
Gabriel Rivera - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 91
All Time: 1,212
