Lenovo B575-1450 RAM Replacement
    1. Lenovo B575-1450 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charger from the computer.
      • Flip the computer upside down.
      Ask FixBot
    2. Lenovo B575-1450 RAM Replacement: step 2, image 1 of 2 Lenovo B575-1450 RAM Replacement: step 2, image 2 of 2
      • Push the right-hand switch outward into the "unlocked" position.
      Ask FixBot
    3. Lenovo B575-1450 RAM Replacement: step 3, image 1 of 3 Lenovo B575-1450 RAM Replacement: step 3, image 2 of 3 Lenovo B575-1450 RAM Replacement: step 3, image 3 of 3
      • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
      Ask FixBot
    1. Lenovo B575-1450 RAM Replacement, Back Panel: step 4, image 1 of 2 Lenovo B575-1450 RAM Replacement, Back Panel: step 4, image 2 of 2
      • The screws are captive to the back panel so they are not to be removed.
      • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
      Ask FixBot
    2. Lenovo B575-1450 RAM Replacement: step 5, image 1 of 1
      • Using a plastic opening tool, pry the back panel from the laptop.
      Ask FixBot
    3. Lenovo B575-1450 RAM Replacement: step 6, image 1 of 1
      • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
      Ask FixBot
    1. Lenovo B575-1450 RAM Replacement, RAM: step 7, image 1 of 2 Lenovo B575-1450 RAM Replacement, RAM: step 7, image 2 of 2
      • Using a plastic opening tool, pry the RAM upwards until the card pops out of the brackets.
      • Pull the RAM out from the slot.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 101
All Time: 1,734
