Up to 20% off select tools
Lenovo B575-1450 Display Panel Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
100
All Time:
2,106
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacing the display screen for the Lenovo B575-1450 takes some time and patience due to the removal of many parts and keeping track of all the small screws. When reinstalling the display screen make sure to be careful with the connectors.
    1. Lenovo B575-1450 Display Panel  Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charger from the computer.
      • Flip the computer upside down.
      Ask FixBot
    2. Lenovo B575-1450 Display Panel  Replacement: step 2, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 2, image 2 of 2
      • Push the right-hand switch outward into the "unlocked" position.
      Ask FixBot
    3. Lenovo B575-1450 Display Panel  Replacement: step 3, image 1 of 3 Lenovo B575-1450 Display Panel  Replacement: step 3, image 2 of 3 Lenovo B575-1450 Display Panel  Replacement: step 3, image 3 of 3
      • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
      Ask FixBot
    1. Lenovo B575-1450 Display Panel  Replacement, Display Panel: step 4, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement, Display Panel: step 4, image 2 of 2
      • Remove both screw covers from the bottom of screen bezel using a plastic spudger. The screws underneath will now be exposed
      Ask FixBot
    2. Lenovo B575-1450 Display Panel  Replacement: step 5, image 1 of 1
      • Using the Phillips #0 Screwdriver, remove the two 4.3 mm screws holding the display to the front bezel.
      Ask FixBot
    3. Lenovo B575-1450 Display Panel  Replacement: step 6, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 6, image 2 of 2
      • Separate the front bezel from the display panel using the plastic opening tool by gently prying around the edges and removing it.
      Ask FixBot
    4. Lenovo B575-1450 Display Panel  Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Using the tweezers carefully disconnect the ZIF connector by pulling cable away from front facing camera that is attached to the back bezel.
      Ask FixBot
    5. Lenovo B575-1450 Display Panel  Replacement: step 8, image 1 of 3 Lenovo B575-1450 Display Panel  Replacement: step 8, image 2 of 3 Lenovo B575-1450 Display Panel  Replacement: step 8, image 3 of 3
      • Using the Phillips #0 Screwdriver, remove the six 4.3 mm screws that connect display screen to the rear bezel.
      • There are two screws in the bottom left and right corners of the frame.
      Ask FixBot
    6. Lenovo B575-1450 Display Panel  Replacement: step 9, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 9, image 2 of 2
      • Using the Phillips #0 Screwdriver, remove the four 2.9 mm screws from each side of the bracket that holds the display panel in place.
      Ask FixBot
    7. Lenovo B575-1450 Display Panel  Replacement: step 10, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 10, image 2 of 2
      • Lay display panel face down on the keyboard.
      • Peel back the flat wire that has the camera's ZIF connector until it is loose from the back of the display.
      • Carefully peel of the clear adhesive tape attached to the primary display ZIF connector using a plastic spudger.
      Ask FixBot
    8. Lenovo B575-1450 Display Panel  Replacement: step 11, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 11, image 2 of 2
      • Place the metal tweezer tips between the ZIF connector and the wire-to-board connection.
      • Carefully separate ZIF wire-to-board connection by pulling metal tweezers in a downward motion.
      • Pull up on flat wire until display is completely disconnected.
      • Be very careful when separating ZIF connections . The ends of the ZIF wire connectors are delicate and can break easily.
      Ask FixBot
Author
with
Carlo Calvillo
772 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 100
All Time: 2,106
