Lenovo B575-1450 CD-ROM Drive Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
90
All Time:
955
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The CD-ROM drive is fairly easy to locate and replace if it is no longer working.
Tools
    1. Lenovo B575-1450 CD-ROM Drive Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charger from the computer.
      • Flip the computer upside down.
      Ask FixBot
    2. Lenovo B575-1450 CD-ROM Drive Replacement: step 2, image 1 of 2 Lenovo B575-1450 CD-ROM Drive Replacement: step 2, image 2 of 2
      • Push the right-hand switch outward into the "unlocked" position.
      Ask FixBot
    3. Lenovo B575-1450 CD-ROM Drive Replacement: step 3, image 1 of 3 Lenovo B575-1450 CD-ROM Drive Replacement: step 3, image 2 of 3 Lenovo B575-1450 CD-ROM Drive Replacement: step 3, image 3 of 3
      • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
      Ask FixBot
    1. Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: step 4, image 1 of 2 Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: step 4, image 2 of 2
      • The screws are captive to the back panel so they are not to be removed.
      • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
      Ask FixBot
    2. Lenovo B575-1450 CD-ROM Drive Replacement: step 5, image 1 of 1
      • Using a plastic opening tool, pry the back panel from the laptop.
      Ask FixBot
    3. Lenovo B575-1450 CD-ROM Drive Replacement: step 6, image 1 of 1
      • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
      Ask FixBot
    1. Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: step 7, image 1 of 2 Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: step 7, image 2 of 2
      • Using the Phillips #00 Screwdriver, remove the 3.4 mm screw from the CD-ROM bracket.
      • This unlocks the CD-ROM drive from the computer
      Ask FixBot
    2. Lenovo B575-1450 CD-ROM Drive Replacement: step 8, image 1 of 2 Lenovo B575-1450 CD-ROM Drive Replacement: step 8, image 2 of 2
      • Pry CD-ROM drive from laptop using a plastic opening tool.
      • Pull the CD-ROM drive the rest of the way out.
      Ask FixBot
1 Guide Comment
Can u please show me how to assemble or fix dvd drive lock mechanism for lenovo e49.
nukuvsh4 - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 90
All Time: 955
