Lenovo 300e Chromebook Left and Right Click Buttons Replacement
    1. Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Back Cover: step 1, image 1 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Back Cover: step 1, image 2 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Back Cover: step 1, image 3 of 3
      • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
      Ask FixBot
    2. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 2, image 1 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 2, image 2 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 2, image 3 of 3
      • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
      Ask FixBot
    1. Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Battery: step 3, image 1 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Battery: step 3, image 2 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Battery: step 3, image 3 of 3
      • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
      Ask FixBot
    2. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 4, image 1 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 4, image 2 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 4, image 3 of 3
      • Disconnect the wiring harness that connects the battery to the motherboard.
      • Lift the battery up and out of the laptop.
      Ask FixBot
    1. Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Left and Right Click Buttons: step 5, image 1 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Left and Right Click Buttons: step 5, image 2 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Left and Right Click Buttons: step 5, image 3 of 3
      • Disconnect the metallic electrical tape by gently pulling back away from the keypad. put it aside for right now.
      Ask FixBot
    2. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 6, image 1 of 2 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 6, image 2 of 2
      • Remove two 5 mm screws from the metal plate using a Phillips #2 screwdriver. once removed, put them aside for now.
      Ask FixBot
    3. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 7, image 1 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 7, image 2 of 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: step 7, image 3 of 3
      • Now, Carefully Remove the left and right click buttons from the laptop. be careful not to break them.
      Ask FixBot
To reassemble your the left and Right buttons on your laptop, please follow this set of instructions in reverse order very carefully. each step requires patience. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 27
All Time: 692
