Lenovo 100e Chromebook Display Removal
    1. Lenovo 100e Chromebook Display Removal, Remove back screws: step 1, image 1 of 1
      • use a 00 Philips head to remove the 10 screws holding the back of it.
      Ask FixBot
    2. Lenovo 100e Chromebook Display Removal, remove back plate: step 2, image 1 of 1
      • Use the opening tool to pry the rear back plate off.
      Ask FixBot
    3. Lenovo 100e Chromebook Display Removal, Disconnect and remove battery: step 3, image 1 of 3 Lenovo 100e Chromebook Display Removal, Disconnect and remove battery: step 3, image 2 of 3 Lenovo 100e Chromebook Display Removal, Disconnect and remove battery: step 3, image 3 of 3
      • 4 screws (00 Philips head)
      • 2 connectors from I/O (DB) to motherboard (DB)
      • battery to motherboard connection
      Ask FixBot
    4. Lenovo 100e Chromebook Display Removal, Disconnect Ribbon Cable: step 4, image 1 of 3 Lenovo 100e Chromebook Display Removal, Disconnect Ribbon Cable: step 4, image 2 of 3 Lenovo 100e Chromebook Display Removal, Disconnect Ribbon Cable: step 4, image 3 of 3
      • For the ribbon cable, Carefully lift the locking flap on the connector, which secures the ribbon cable in place. These flaps are usually very delicate, so use a spudger or your fingernail to gently lift it up. It doesn’t come off entirely; just lifts up a little to release the tension on the cable.
      • Once the flap is lifted, gently pull the ribbon cable out of the connector. Pull straight out and avoid side-to-side motion to ensure the cable and its contacts aren’t damaged.
      Ask FixBot
    5. Lenovo 100e Chromebook Display Removal, disconnect battery connection to motherboard: step 5, image 1 of 2 Lenovo 100e Chromebook Display Removal, disconnect battery connection to motherboard: step 5, image 2 of 2
      • Use a plastic tool such as the opening tool or opening pick to carefully disconnect the battery from the motherboard
      • This part is kind of difficult be careful not to break this cord pushing it out.
      Ask FixBot
    6. Lenovo 100e Chromebook Display Removal, Remove screen bezel: step 6, image 1 of 3 Lenovo 100e Chromebook Display Removal, Remove screen bezel: step 6, image 2 of 3 Lenovo 100e Chromebook Display Removal, Remove screen bezel: step 6, image 3 of 3
      • flip device over to remove the screen bezel.
      • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
      • Insert the spudger into the gap between the hinges and pull up to detach the connections.
      • Set aside once removed
      Ask FixBot
    7. Lenovo 100e Chromebook Display Removal, Remove display: step 7, image 1 of 2 Lenovo 100e Chromebook Display Removal, Remove display: step 7, image 2 of 2
      • Remove 4 screws using the Phillips #00 screwdriver bit.
      • Carefully pull the screen back onto the lower assembly.
      Ask FixBot
    8. Lenovo 100e Chromebook Display Removal, Disconnect Display cord: step 8, image 1 of 2 Lenovo 100e Chromebook Display Removal, Disconnect Display cord: step 8, image 2 of 2
      • Peel back the protective tape over the display cable using the spudger. Gently lift the black bar latch holding the cable in place, until the cable becomes loose. Pull the cable free and remove the display.
      Ask FixBot
Emilio Acuna-reyes
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 39
All Time: 546
