Leica Z2X Lens Cover Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
120
All Time:
4,168
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Difficult
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
    1. Leica Z2X Lens Cover Replacement, Remove the Bottom Screws: step 1, image 1 of 1
      • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
      • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
      Ask FixBot
    2. Leica Z2X Lens Cover Replacement, Open the Back Door: step 2, image 1 of 1
      • Open the back door on the camera by pushing down on the door latch.
      Ask FixBot
    3. Leica Z2X Lens Cover Replacement, Remove the Bottom Plate: step 3, image 1 of 1
      • Apply pressure to the bottom plate and it will pop off.
      • From here, you can replace the bottom plate, or continue on to further steps.
      Ask FixBot
    1. Leica Z2X Lens Cover Replacement, Lens Motor: step 4, image 1 of 1
      • Remove the five screws marked in the picture.
      Ask FixBot
    2. Leica Z2X Lens Cover Replacement: step 5, image 1 of 1
      • Apply pressure until the piece you unscrewed in the last step pops off.
      Ask FixBot
    3. Leica Z2X Lens Cover Replacement: step 6, image 1 of 1
      • Unscrew the four screws on the back of this piece to the lower-left corner of the lens.
      Ask FixBot
    4. Leica Z2X Lens Cover Replacement: step 7, image 1 of 1
      • Removing the lens motor cover, you should be left with these four pieces.
      Ask FixBot
    5. Leica Z2X Lens Cover Replacement: step 8, image 1 of 1
      • Located underneath these four pieces is the lens motor.
      Ask FixBot
    6. Leica Z2X Lens Cover Replacement: step 9, image 1 of 1
      • Now that you've removed the bottom plate, you can pull apart the front and back covers.
      • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
      Ask FixBot
    7. Leica Z2X Lens Cover Replacement: step 10, image 1 of 1
      • Next, the back cover.
      • Apply pressure to remove the back plate.
      • Potential for device damage: Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
      • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
      Ask FixBot
    8. Leica Z2X Lens Cover Replacement: step 11, image 1 of 1
      • You should now have removed the front and back plates.
      Ask FixBot
    9. Leica Z2X Lens Cover Replacement: step 12, image 1 of 1
      • Remove the four screws holding on the front panel surrounding the lens.
      Ask FixBot
    10. Leica Z2X Lens Cover Replacement: step 13, image 1 of 1
      • Remove the three gears under the panel you removed in the last step and the lens motor should be able to be removed.
      Ask FixBot
    1. Leica Z2X Lens Cover Replacement, Lens Cover: step 14, image 1 of 1
      • Now that the lens motor has been removed, you can apply pressure to the back of the lens and push it out.
      • From here, locate the three screws near the front of the lens.
      • Unscrew these three screws.
      Ask FixBot
    2. Leica Z2X Lens Cover Replacement: step 15, image 1 of 1
      • From here, you can pull out the small disk containing the lens cover.
      • Unscrew the four screws on the back and pull the two pieces of the disk apart.
      Ask FixBot
    3. Leica Z2X Lens Cover Replacement: step 16, image 1 of 1
      • From here, you can replace any broken parts in the lens cover.
      Ask FixBot
Kenny
57 Reputation
3 Guides authored
Cal Poly, Team 18-19, Garner Spring 2011 Member of Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 120
All Time: 4,168
