Lego Dimensions Starter Pack USB Cable Replacement
    1. Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: step 1, image 1 of 2 Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: step 1, image 2 of 2
      • Be careful not to crack the cover.
      • Use the metal spudger to gently pry open the corners of the top cover.
      Ask FixBot
    2. Lego Dimensions Starter Pack USB Cable Replacement: step 2, image 1 of 1
      • Be careful not to crack the top cover.
      • Use the metal spudger to gently pry up the center of the top cover.
      Ask FixBot
    3. Lego Dimensions Starter Pack USB Cable Replacement: step 3, image 1 of 1
      • Pull the top cover off.
      Ask FixBot
    4. Lego Dimensions Starter Pack USB Cable Replacement: step 4, image 1 of 1
      • Lift up the circular illumination stand and remove it from the toy pad.
      Ask FixBot
    5. Lego Dimensions Starter Pack USB Cable Replacement: step 5, image 1 of 1
      • Lift up the white L-shaped pieces and remove them from the toy pad.
      Ask FixBot
    1. Lego Dimensions Starter Pack USB Cable Replacement, USB Cable: step 6, image 1 of 1
      • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
      • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
      • Remove the USB cable from the toy pad.
      Ask FixBot
5 other people completed this guide.
Alyssa Lach
563 Reputation
4 Guides authored
IUPUI, Team S5-G2, Baechle Fall 2017 Member of IUPUI, Team S5-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G2
2 Members
48 Guides authored
4 Guide Comments
Where do you buy the USB cable from?
jaimea371 - Reply Share
I bought a lego dimensions pad (tested and working cable) then opened it, grabbed the usb cable and, replaced the broken cable on my old lego dimensions pad. It worked. Maybe give a try.
tictac25 - Reply Share
mguzmanv - Reply Share
I used the usb cable from a different pad, and, replaced the broken cable on my lego dimensions pad (xbox one). It worked. Maybe give a try.
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 98
All Time: 7,288
