Lego Dimensions Starter Pack Motherboard Replacement
  1. Lego Dimensions Starter Pack Motherboard Replacement, Top Cover Parts: step 1, image 1 of 2 Lego Dimensions Starter Pack Motherboard Replacement, Top Cover Parts: step 1, image 2 of 2
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
    Ask FixBot
  2. Lego Dimensions Starter Pack Motherboard Replacement: step 2, image 1 of 1
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
    Ask FixBot
  3. Lego Dimensions Starter Pack Motherboard Replacement: step 3, image 1 of 1
    • Pull the top cover off.
    Ask FixBot
  4. Lego Dimensions Starter Pack Motherboard Replacement: step 4, image 1 of 1
    • Lift up the circular illumination stand and remove it from the toy pad.
    Ask FixBot
  5. Lego Dimensions Starter Pack Motherboard Replacement: step 5, image 1 of 1
    • Lift up the white L-shaped pieces and remove them from the toy pad.
    Ask FixBot
  6. Lego Dimensions Starter Pack Motherboard Replacement, USB Cable: step 6, image 1 of 1
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
    Ask FixBot
  7. Lego Dimensions Starter Pack Motherboard Replacement, LED Chip: step 7, image 1 of 1
    • Pull the black connector of the ribbon away from the LED chip, keeping the connector parallel to the board.
    • Disconnect the connector on the other LED chip as well, if replacing both LED chips or the motherboard
    Ask FixBot
  8. Lego Dimensions Starter Pack Motherboard Replacement: step 8, image 1 of 1
    • Pull the ribbon away from the black connector of the LED chips.
    • Disconnect the ribbon from the other LED chip as well, if replacing both LED chips or the motherboard.
    Ask FixBot
  9. Lego Dimensions Starter Pack Motherboard Replacement: step 9, image 1 of 1
    • Lift up both LED chips. As you are lifting, pull towards the motherboard to release it from the toy pad cover.
    Ask FixBot
  10. Lego Dimensions Starter Pack Motherboard Replacement: step 10, image 1 of 1
    • Lift up the motherboard, and remove the motherboard and LED chips from the toy pad.
    Ask FixBot
  11. Lego Dimensions Starter Pack Motherboard Replacement: step 11, image 1 of 1
    • Flip the motherboard and LED chips over.
    • Desolder the LED chip from the motherboard.
    • Desolder both LED chips, if replacing both LED chips or the motherboard
    • Separate the LED chip(s) from the motherboard.
    • Refer to this guide for soldering and desoldering tips.
    Ask FixBot
  12. Lego Dimensions Starter Pack Motherboard Replacement, Motherboard: step 12, image 1 of 1
    • Separate the motherboard from both LED chips.
    Ask FixBot
Alyssa Lach
563 Reputation
4 Guides authored
IUPUI, Team S5-G2, Baechle Fall 2017 Member of IUPUI, Team S5-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G2
2 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 1,107
