Tools
Introduction
Go to step 1 ↓The LED chips cause the toy pad to light up during gameplay. The LED chip may need to be replaced if the toy pad does not light up. This guide will show how to remove the LED chips.
Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
Remove the USB cable from the toy pad.
Pull the black connector of the ribbon away from the LED chip, keeping the connector parallel to the board.
Disconnect the connector on the other LED chip as well, if replacing both LED chips or the motherboard
