Left-Handed Fender Squier Electric Guitar String Replacement
    1. Left-Handed Fender Squier Electric Guitar String Replacement, String: step 1, image 1 of 1
      • Place the guitar on a flat surface with the tuning pegs facing you.
      Ask FixBot
    2. Left-Handed Fender Squier Electric Guitar String Replacement: step 2, image 1 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 2, image 2 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 2, image 3 of 3
      • Use a guitar string winder to drop the tuning and loosen each of the strings.
      • Use a wire cutter to cut each of the strings in the middle of the fretboard.
      • Guitar strings can be sharp and cutting them without loosening them first can cause harm to the user.
      Ask FixBot
    3. Left-Handed Fender Squier Electric Guitar String Replacement: step 3, image 1 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 3, image 2 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 3, image 3 of 3
      • To remove the top half of the string from the guitar, turn the tuning pegs to loosen the string until you can pull it from the guitar.
      • Remove the bottom half of the string by pushing each string through the front of the bridge saddle and pulling it out through the back.
      Ask FixBot
    4. Left-Handed Fender Squier Electric Guitar String Replacement: step 4, image 1 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 4, image 2 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 4, image 3 of 3
      • Start restringing with the thickest (E) string.
      • Push the new string through the back of the bridge and pull it through the front of the saddle.
      Ask FixBot
    5. Left-Handed Fender Squier Electric Guitar String Replacement: step 5, image 1 of 2 Left-Handed Fender Squier Electric Guitar String Replacement: step 5, image 2 of 2
      • Pull the string so that it is parallel with the fretboard.
      • Place the string through the first tuning post.
      Ask FixBot
    6. Left-Handed Fender Squier Electric Guitar String Replacement: step 6, image 1 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 6, image 2 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 6, image 3 of 3
      • Hold the guitar and place your thumb on the first fret to ensure the string stays in place.
      • Insert the guitar string winder into the the tuning peg.
      • Turn the guitar string winder clockwise to tighten the string.
      • The process of replacing strings A, G, and B is the same and you can follow steps 4 through 6.
      • Only tighten the string until it stays in place. If you tighten it too much the string might snap which may result in injury.
      Ask FixBot
    7. Left-Handed Fender Squier Electric Guitar String Replacement: step 7, image 1 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 7, image 2 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 7, image 3 of 3
      • Insert the D string from the back of the bridge and pull it through the saddle at the front of the guitar.
      • Pull the wire so that it is parallel to the fretboard.
      • Make sure to place the string under the string tree.
      Ask FixBot
    8. Left-Handed Fender Squier Electric Guitar String Replacement: step 8, image 1 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 8, image 2 of 3 Left-Handed Fender Squier Electric Guitar String Replacement: step 8, image 3 of 3
      • Insert the guitar string winder into the the tuning peg and turn it clockwise.
      • The process of replacing the last e string is the same as steps 7 and 8.
      • Only tighten the string until it stays in place. If you tighten it too much the string might snap which may cause injury.
      Ask FixBot
    9. Left-Handed Fender Squier Electric Guitar String Replacement: step 9, image 1 of 2 Left-Handed Fender Squier Electric Guitar String Replacement: step 9, image 2 of 2
      • Use a wire cutter to cut the extra length of wire.
      • You should leave an inch or two of each string onto the tuning posts to allow for a greater tuning range.
      Ask FixBot
    10. Left-Handed Fender Squier Electric Guitar String Replacement: step 10, image 1 of 2 Left-Handed Fender Squier Electric Guitar String Replacement: step 10, image 2 of 2
      • Use a guitar string winder to tighten/loosen strings in order to correctly tune each string to its respective note.
      • The usual 6 notes on a guitar are E, A, D, G, B, e, in the order of the thickest string to the thinnest.
      • Smartphone apps or guitar tuners will help with the tuning process.
      • While tuning, wiggle each string back and forth to remove slack and prevent slipping so the strings will maintain in tune longer.
      Ask FixBot
4 other people completed this guide.
Manuel Serrano
229 Reputation
1 Guide authored
UC Davis, Team 2-3, Morris Spring 2023 Member of UC Davis, Team 2-3, Morris Spring 2023
UCD-MORRIS-S23S2G3
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 72
All Time: 1,253
