Left Nintendo Switch NES Controller Charging Rail Replacement
    1. Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the back casing: step 1, image 1 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the back casing: step 1, image 2 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the back casing: step 1, image 3 of 3
      • Use a Tri-point #Y00 screwdriver to remove the six 6.0 mm screws securing the back case.
      • Remove the back case from the controller.
      Ask FixBot
    2. Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the battery housing: step 2, image 1 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the battery housing: step 2, image 2 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the battery housing: step 2, image 3 of 3
      • Use a Phillips #000 to remove three 3.0 mm screws holding the battery and it's housing.
      • Remove the battery housing with the battery from the main board and set it aside.
      • At this point the battery is still attached to the motherboard by a connector so don't pull it off the board.
      • If you're not replacing the battery, you can leave it attached to the board to complete the repair, just be careful when moving them so you don't damage the connection.
      Ask FixBot
    3. Left Nintendo Switch NES Controller Charging Rail Replacement, Pry the ZIF connectors up: step 3, image 1 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Pry the ZIF connectors up: step 3, image 2 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Pry the ZIF connectors up: step 3, image 3 of 3
      • Use the tip of a spudger or your fingernail to flip up the small locking flaps on the two ZIF Connectors. Then, you can safely pull the cable out.
      • Be sure to pry up on the hinged flap, not the connector socket.
      Ask FixBot
    4. Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the charging rail: step 4, image 1 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the charging rail: step 4, image 2 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the charging rail: step 4, image 3 of 3
      • Use a Phillips #000 to remove the single 3.0 mm screw holding the charging rail to the back plate.
      • Remove the charging rail.
      Ask FixBot
    5. Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the rail PCB: step 5, image 1 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the rail PCB: step 5, image 2 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the rail PCB: step 5, image 3 of 3
      • Use a Phillips #000 screwdriver to remove two 3.0mm screws from the rail PCB.
      • Remove the charging rail PCB.
      Ask FixBot
    6. Left Nintendo Switch NES Controller Charging Rail Replacement, Take the SL, SR and Sync buttons out: step 6, image 1 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Take the SL, SR and Sync buttons out: step 6, image 2 of 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Take the SL, SR and Sync buttons out: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers, remove the SL and SR buttons.
      • Do the same for the Sync button between them.
      Ask FixBot
We hope you enjoy your new and improved Charging Rail for your Nintendo Switch NES Controller.
To put the device back together, follow this guide in reverse.
4 other people completed this guide.
Dominik Szwec
178 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 90
All Time: 2,612
