Up to 20% off select tools
Left Joy-Con Joystick Replacement
Views: 955K
View statistics:
Past 24 Hours:
292
Past 7 Days:
1,898
Past 30 Days:
8,166
All Time:
954,621
Comments: 272
104 comments on steps, 168 guide comments.
Go to guide comments
Completed: 1105
1105 people have marked this guide "completed." Will you be next?
Favorites: 192
192 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
The Nintendo Switch comes with two Joy-Con controllers. This guide shows how to replace the joystick of the left Joy-Con. The procedure for repairing the right Joy-Con is different, so be sure to follow the correct set of instructions for your controller.
Video Overview
    1. Left Joy-Con Joystick Replacement, Remove the back panel screws: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Remove the four Tri-Point Y00 screws from the back panel of the Joy-Con.
      • These screws are each 6.2 mm long, but it's still a good idea to keep them organized and make sure they go back in their proper places!
      Ask FixBot
    2. Left Joy-Con Joystick Replacement: step 2, image 1 of 3 Left Joy-Con Joystick Replacement: step 2, image 2 of 3 Left Joy-Con Joystick Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam at the bottom edge of the controller (opposite the L and ZL buttons).
      • Slowly slide the flat edge of your opening pick up the side of the Joy-Con.
      • Be careful not to slide the opening pick too far inside the Joy-Con. This may damage the inner components. The back panel loosens fairly easily, so not much pressure is needed.
      Ask FixBot
    3. Left Joy-Con Joystick Replacement: step 3, image 1 of 2 Left Joy-Con Joystick Replacement: step 3, image 2 of 2
      • With the charging rail facing away from you, open the the Joy-Con like a book.
      • Don’t try to fully remove the back panel yet. There are still two cables connecting the charging rail to the motherboard.
      • During reassembly, make sure the SL/SR cable is lightly bent under the battery compartment before clipping the two halves of the joy‑con together. Otherwise, you might crease the cable and damage it.
      Ask FixBot
    4. Left Joy-Con Joystick Replacement: step 4, image 1 of 2 Left Joy-Con Joystick Replacement: step 4, image 2 of 2
      • Use a spudger to gently pry the battery connector straight up from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
      • Be very careful as you pry up the connector—if it doesn't come up with the spudger, try gently pulling the cables straight up from the board to disconnect it.
      • During reassembly, press the connector straight down into its socket on the board to reconnect the battery.
      Ask FixBot
    5. Left Joy-Con Joystick Replacement: step 5, image 1 of 3 Left Joy-Con Joystick Replacement: step 5, image 2 of 3 Left Joy-Con Joystick Replacement: step 5, image 3 of 3
      • Insert an opening pick between the battery and the Joy-Con housing.
      • Gently pry out the battery, which is lightly taped in place.
      • Be careful not to deform or puncture the battery—it can catch fire or explode if damaged.
      Ask FixBot
    6. Left Joy-Con Joystick Replacement: step 6, image 1 of 1
      • Remove the three 3.5 mm golden Phillips #00 screws from the midframe.
      • Do not attempt to remove the midframe yet. There is a fragile cable that still connects the ZL button on the midframe to the motherboard underneath.
      Ask FixBot
    7. Left Joy-Con Joystick Replacement: step 7, image 1 of 1
      • Carefully flip the midframe over, away from the motherboard, in the opposite direction to the back panel.
      • Do your best not to stress the thin ribbon cable attached to the ZL button during this step.
      Ask FixBot
    8. Left Joy-Con Joystick Replacement: step 8, image 1 of 3 Left Joy-Con Joystick Replacement: step 8, image 2 of 3 Left Joy-Con Joystick Replacement: step 8, image 3 of 3
      Buy
      • The ZL button cable is locked in place by a small ZIF connector on the motherboard. Use tweezers or a spudger to flip up the ZIF connector lock opposite the cable.
      • Use tweezers to gently pull the ZL button flex cable out of the ZIF connector socket. The midframe is now disconnected and can be removed.
      Ask FixBot
    9. Left Joy-Con Joystick Replacement: step 9, image 1 of 3 Left Joy-Con Joystick Replacement: step 9, image 2 of 3 Left Joy-Con Joystick Replacement: step 9, image 3 of 3
      • The ribbon cable connecting the minus button of the Joy-Con to the motherboard runs over the back of the joystick. It is possible to remove the joystick without disconnecting this cable, but it's much easier to do so when it is disconnected and out of the way.
      • Unlock the minus button’s ZIF connector and disconnect the cable.
      Ask FixBot
    10. Left Joy-Con Joystick Replacement: step 10, image 1 of 3 Left Joy-Con Joystick Replacement: step 10, image 2 of 3 Left Joy-Con Joystick Replacement: step 10, image 3 of 3
      • Finally, the joystick is locked into place by one last ZIF connector. Carefully flip the ZIF lock upward and disconnect the cable.
      Ask FixBot
    11. Left Joy-Con Joystick Replacement: step 11, image 1 of 1
      • Remove the two 3.5 mm Phillips #00 screws from the joystick.
      Ask FixBot
    12. Left Joy-Con Joystick Replacement: step 12, image 1 of 2 Left Joy-Con Joystick Replacement: step 12, image 2 of 2
      • Carefully remove the joystick from its housing.
      • There is a thin black gasket around the hole where the joystick pokes through the Joy-Con. Do your best not to disturb this gasket as you remove the joystick!
      • Once the Joy-Con is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick. Additionally, you may need to power cycle your Switch by holding down the power button for 10-15 seconds until it turns off, then turning it back on.
      Ask FixBot
    13. Left Joy-Con Joystick Replacement, Install the Gulikit joystick ring sticker: step 13, image 1 of 2 Left Joy-Con Joystick Replacement, Install the Gulikit joystick ring sticker: step 13, image 2 of 2
      • If you've replaced the joystick with a Gulikit module and it came with a joystick ring sticker, follow the next two steps to install it.
      • Use your fingers to pull the thumbstick off of the Gulikit joystick module.
      Ask FixBot
    14. Left Joy-Con Joystick Replacement: step 14, image 1 of 3 Left Joy-Con Joystick Replacement: step 14, image 2 of 3 Left Joy-Con Joystick Replacement: step 14, image 3 of 3
      • Peel the ring sticker from its liner.
      • If the sticker center is still attached, separate and remove it from the ring.
      • Set the ring sticker in the joystick recess and press it with your fingers for a few seconds to attach it.
      Ask FixBot
1105 other people completed this guide.
Author
with
Taylor Dixon
73,293 Reputation
94 Guides authored
168 Guide Comments
Thx This really helped
Stev Steve - Reply Share
Thanks Kyler - I just replaced 4 joysticks and they’re all working perfectly.
One final step to remember to go in and calibrate the controller.
David K - Reply Share
You're welcome I'm glad I could assist you in your repairs!
Kyler Saunders - Reply Share
Thanks. This was just the right amount of info and now my left stick drift is gone….for now.
Jason Hoover - Reply Share
I would recommend at least once a month take a can of compressed air and spray the joystick internals to clear it of any dust or debris.
Nick Mensch - Reply Share
Past 24 Hours: 292
Past 7 Days: 1,898
Past 30 Days: 8,166
All Time: 954,621
