Lefant M210 Wheel Assembly Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
9
Past 7 Days:
69
Past 30 Days:
251
All Time:
2,541
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide provides step-by-step instructions for replacing the wheel assembly on the Lefant M210 robot vacuum.
Tools
    1. Lefant M210 Wheel Assembly Replacement, Brush: step 1, image 1 of 2 Lefant M210 Wheel Assembly Replacement, Brush: step 1, image 2 of 2
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
      Ask FixBot
    2. Lefant M210 Wheel Assembly Replacement: step 2, image 1 of 3 Lefant M210 Wheel Assembly Replacement: step 2, image 2 of 3 Lefant M210 Wheel Assembly Replacement: step 2, image 3 of 3
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      Ask FixBot
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
      Ask FixBot
    1. Lefant M210 Wheel Assembly Replacement, Wheel Assembly: step 4, image 1 of 1
      • Use a Phillips screwdriver to remove four screws near each wheel.
      Ask FixBot
    2. Lefant M210 Wheel Assembly Replacement: step 5, image 1 of 2 Lefant M210 Wheel Assembly Replacement: step 5, image 2 of 2
      • Remove the plastic cover next to each wheel.
      • Grip both sides of the wheel and pull upwards.
      • The wheels of the device require some force to remove.
      • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
      Ask FixBot
    3. Lefant M210 Wheel Assembly Replacement: step 6, image 1 of 3 Lefant M210 Wheel Assembly Replacement: step 6, image 2 of 3 Lefant M210 Wheel Assembly Replacement: step 6, image 3 of 3
      • Hold the wheel up and detach the connector to release it from the device.
      Ask FixBot
Adrian pg
147 Reputation
1 Guide authored
CSU Los Angeles, Team 2-4, Kershman Fall 2024 Member of CSU Los Angeles, Team 2-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 69
Past 30 Days: 251
All Time: 2,541
