Lefant M210 Battery Replacement
Views: 18K
View statistics:
Past 24 Hours:
33
Past 7 Days:
247
Past 30 Days:
1,042
All Time:
17,890
Comments: 10
4 comments on steps, 6 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
Robotic vacuum batteries generally last 2-3 years, depending on usage. Over time, you may notice that the battery holds less charge, requires more frequent recharging, or a decrease in cleaning performance. Use this guide to help replace your battery and restore your Lefant M210 robot vacuum to like-new performance.
Before you begin this repair, turn off the vacuum.
Tools
    1. Lefant M210 Battery Replacement, Brush: step 1, image 1 of 2 Lefant M210 Battery Replacement, Brush: step 1, image 2 of 2
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
      Ask FixBot
    2. Lefant M210 Battery Replacement: step 2, image 1 of 3 Lefant M210 Battery Replacement: step 2, image 2 of 3 Lefant M210 Battery Replacement: step 2, image 3 of 3
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      Ask FixBot
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
      Ask FixBot
    1. Lefant M210 Battery Replacement, Wheel Assembly: step 4, image 1 of 1
      • Use a Phillips screwdriver to remove four screws near each wheel.
      Ask FixBot
    2. Lefant M210 Battery Replacement: step 5, image 1 of 2 Lefant M210 Battery Replacement: step 5, image 2 of 2
      • Remove the plastic cover next to each wheel.
      • Grip both sides of the wheel and pull upwards.
      • The wheels of the device require some force to remove.
      • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
      Ask FixBot
    3. Lefant M210 Battery Replacement: step 6, image 1 of 3 Lefant M210 Battery Replacement: step 6, image 2 of 3 Lefant M210 Battery Replacement: step 6, image 3 of 3
      • Hold the wheel up and detach the connector to release it from the device.
      Ask FixBot
    1. Lefant M210 Battery Replacement, Dustbin Filters: step 7, image 1 of 1
      • Open the dustbin compartment.
      Ask FixBot
    2. Lefant M210 Battery Replacement: step 8, image 1 of 2 Lefant M210 Battery Replacement: step 8, image 2 of 2
      • With your hands, gently pull the dustbin to remove it from its compartment.
      Ask FixBot
    3. Lefant M210 Battery Replacement: step 9, image 1 of 1
      • With your hands, pull off the filter compartment from the dustbin.
      Ask FixBot
    4. Lefant M210 Battery Replacement: step 10, image 1 of 1
      • Pull off the filter from the filter compartment.
      Ask FixBot
    1. Lefant M210 Battery Replacement, Battery: step 11, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the six screws around the bottom edge of the device.
      Ask FixBot
    2. Lefant M210 Battery Replacement: step 12, image 1 of 2 Lefant M210 Battery Replacement: step 12, image 2 of 2
      • Carefully flip the vacuum back right-side-up, making sure you're holding it all together so that the bottom portion doesn't fall out.
      • Rotate the vacuum so that the Lefant logo is facing you.
      • Carefully lift the white cover of the vacuum, opening it like a laptop, from front to back.
      • Rest the open cover something stable, like a wall.
      Ask FixBot
    3. Lefant M210 Battery Replacement: step 13, image 1 of 2 Lefant M210 Battery Replacement: step 13, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the three screws securing the motherboard to the device.
      Ask FixBot
    4. Lefant M210 Battery Replacement: step 14, image 1 of 1
      • Carefully lift the motherboard, ensuring you don't rip any cables that are connected to it.
      • The battery should be under the motherboard.
      Ask FixBot
    5. Lefant M210 Battery Replacement: step 15, image 1 of 2 Lefant M210 Battery Replacement: step 15, image 2 of 2
      • Push the two retaining clips away from the battery while pulling the battery up from the tabs attached to it to free it.
      • Retaining clips
      • Battery tabs
      • Work on freeing one side at a time so that it's easier to free the battery.
      Ask FixBot
    6. Lefant M210 Battery Replacement: step 16, image 1 of 1
      • When the battery is free from it's housing, lift it out completely using its pull tabs.
      Ask FixBot
    7. Lefant M210 Battery Replacement: step 17, image 1 of 2 Lefant M210 Battery Replacement: step 17, image 2 of 2
      • Locate the battery connection wire and carefully pull apart the connection.
      • Pinch the motherboard's wire connector and pull the connection apart.
      • The connection is secured by a clothespin-like mechanism.
      • When you replace your battery with a new one, allow the robot vacuum to fully charge for a few hours before using it again.
      Ask FixBot
6 other people completed this guide.
Darien Amador
328 Reputation
1 Guide authored
CSU Los Angeles, Team 2-4, Kershman Fall 2024 Member of CSU Los Angeles, Team 2-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G4
4 Members
48 Guides authored
6 Guide Comments
Great guide! Any knowledge on how or why mine beeps twice even when it is on the ground?
Jonathan Manuel - Reply Share
Thank you for the helpful guide, however, after replacing my battery, it definitely has a much shorter lifespan, and it is unable to find the charger before it dies.
Tee Cee - Reply Share
I thought it was because I needed a new battery. My stops about 1min after start. When I put it back to the charger it indicates battery charged by showing the blue light. Still after 1 min of operation it dies. That's the reason why i want to replace the battery. Is that what yours is doing too even after replacing the battery?
Zed - Reply Share
Thanks for the guide.
As for those that stumble upon this, mind that ******if you only want to access the battery, steps 10 to 16 are the only on you need.
Sylvain “Neoblasphem” Mourot - Reply Share
Bought new batt, installed it and same problem. Red light, not charging. I guess it’s dead for good.
Kelly In Cali - Reply Share
Past 24 Hours: 33
Past 7 Days: 247
Past 30 Days: 1,042
All Time: 17,890
