Up to 20% off select tools
Led Lenser P2 BM Button Disassembly
Views: 5.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
67
Past 30 Days:
311
All Time:
5,736
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Introduction
Go to step 1 ↓
I've had this small pocket light for 10 years and even after 3 moths left under the snow I've only ever had one problem (twice). The button can stop working, however this was easily fixed by disassembling the button and removing dirt from inside. Here's how I did it.
    1. Led Lenser  P2 BM  Button Disassembly, Unscrew rear cap from the main housing: step 1, image 1 of 1
      • This is exactly how you would do it if you were changing the battery.
      Ask FixBot
    2. Led Lenser  P2 BM  Button Disassembly, Remove O-ring: step 2, image 1 of 1
      • Remove the small O-Ring, I used a plastic toothpick.
      Ask FixBot
    3. Led Lenser  P2 BM  Button Disassembly, Screw apart cap: step 3, image 1 of 2 Led Lenser  P2 BM  Button Disassembly, Screw apart cap: step 3, image 2 of 2
      • Now we will unscrew the aluminum cap from the plastic lower part. I used a pair of pliers to carefully hold the plastic part while unscrewing the aluminum part with my finger. Left-hand thread.
      Ask FixBot
    4. Led Lenser  P2 BM  Button Disassembly, Split housing: step 4, image 1 of 1
      • The plastic housing holds the actual button assembly and is made from two halves, These can carefully be pried apart wit a knife.
      Ask FixBot
    5. Led Lenser  P2 BM  Button Disassembly, Open button assembly: step 5, image 1 of 2 Led Lenser  P2 BM  Button Disassembly, Open button assembly: step 5, image 2 of 2
      • Button assembly mark in red circle. This is held together by 4 plastic "rivets" on the connector side, marked in green. Cafully cut these flush like in the picture.
      Ask FixBot
    6. Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: step 6, image 1 of 2 Led Lenser  P2 BM  Button Disassembly, Separate the button. Clean and ispect: step 6, image 2 of 2
      • You can then pry of the "lid" like in the third picture.
      • Carefully remove the inner springs and plungers. In the picture one small plunger is still in the top of the button.
      • In my case the problem was a tiny plastic "!shaving" inside the button blocking it from making a connection, Market with yellow arrow.
      Ask FixBot
    7. Led Lenser  P2 BM  Button Disassembly, Reassemble: step 7, image 1 of 1
      • Is reversed of disassembly but you don't need to glue the button together (the small plastic "rivets" are now broken) because the two part plastic housing will keep it together when assembled.
      • I have used it like this for years until the same problem happen again, so added some new images while fixing it again.
      Ask FixBot
Author
with
Hans
430 Reputation
2 Guides authored
3 Guide Comments
Dear Hans.
I have used the same P3 LED for many years in bad switch condition.
Today I cleared this problem with your solution.
Very thank you & I'm appreciate to you.
DS2DDE
from Seoul, Korea.
김도욱 - Reply Share
can you show how to take the front part apart?
Eric Secreve - Reply Share
@ericsecreve Sadly I lost the light on an exercise, it's somewhere out in the woods now, all alone, cold and wet.
Hans - Reply Share
Past 24 Hours: 4
Past 7 Days: 67
Past 30 Days: 311
All Time: 5,736
