Leapfrog My Own Leaptop Battery Replacement Guide
    1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: step 1, image 1 of 1
      • Flip over device so that back portion of the device is facing you.
      Ask FixBot
    2. Leapfrog My Own Leaptop Battery Replacement Guide: step 2, image 1 of 1
      • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
      • Please note that the screw cannot be removed as it is attached to the battery cover.
      Ask FixBot
    3. Leapfrog My Own Leaptop Battery Replacement Guide: step 3, image 1 of 2 Leapfrog My Own Leaptop Battery Replacement Guide: step 3, image 2 of 2
      • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
      • Remove the three AA batteries.
      • Note the direction of the batteries for when reassembling.
      Ask FixBot
Finish Line
Jonathan Fitzer
629 Reputation
3 Guides authored
USF Tampa, Team 14-6, Lacy Spring 2016 Member of USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Members
36 Guides authored
1 Guide Comment
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 68
All Time: 4,625
