Leapfrog LeapPad 3 Display Assembly Replacement
Video Overview
    1. Leapfrog LeapPad 3 Display Assembly Replacement, Battery: step 1, image 1 of 3 Leapfrog LeapPad 3 Display Assembly Replacement, Battery: step 1, image 2 of 3 Leapfrog LeapPad 3 Display Assembly Replacement, Battery: step 1, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
      • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
      • You will not need to pry the case off.
      Ask FixBot
    2. Leapfrog LeapPad 3 Display Assembly Replacement: step 2, image 1 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 2, image 2 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 2, image 3 of 3
      • Unplug the battery from the motherboard with your hands.
      • The battery sits to the right of the motherboard.
      Ask FixBot
    3. Leapfrog LeapPad 3 Display Assembly Replacement: step 3, image 1 of 2 Leapfrog LeapPad 3 Display Assembly Replacement: step 3, image 2 of 2
      • Pry the battery gently off of the plastic platform with an opening tool.
      • Do not to puncture the battery, as the material inside can be dangerous.
      Ask FixBot
    1. Leapfrog LeapPad 3 Display Assembly Replacement, Speaker: step 4, image 1 of 2 Leapfrog LeapPad 3 Display Assembly Replacement, Speaker: step 4, image 2 of 2
      • Disconnect the audio cord from the motherboard using a plastic opening tool.
      • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
      • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
      Ask FixBot
    2. Leapfrog LeapPad 3 Display Assembly Replacement: step 5, image 1 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 5, image 2 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 5, image 3 of 3
      • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
      Ask FixBot
    3. Leapfrog LeapPad 3 Display Assembly Replacement: step 6, image 1 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 6, image 2 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 6, image 3 of 3
      • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
      • Remove the board and speaker from the device.
      Ask FixBot
    1. Leapfrog LeapPad 3 Display Assembly Replacement, Motherboard: step 7, image 1 of 2 Leapfrog LeapPad 3 Display Assembly Replacement, Motherboard: step 7, image 2 of 2
      • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
      Ask FixBot
    2. Leapfrog LeapPad 3 Display Assembly Replacement: step 8, image 1 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 8, image 2 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 8, image 3 of 3
      • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
      Ask FixBot
    3. Leapfrog LeapPad 3 Display Assembly Replacement: step 9, image 1 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 9, image 2 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 9, image 3 of 3
      • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
      • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
      • The device was rotated 180 degrees in order to unplug the display assembly cord.
      Ask FixBot
    1. Leapfrog LeapPad 3 Display Assembly Replacement, Display Assembly: step 10, image 1 of 2 Leapfrog LeapPad 3 Display Assembly Replacement, Display Assembly: step 10, image 2 of 2
      • Unscrew the eight 6.5mm Phillips #0 screws from the plastic casing.
      Ask FixBot
    2. Leapfrog LeapPad 3 Display Assembly Replacement: step 11, image 1 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 11, image 2 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 11, image 3 of 3
      • Remove the covering with your hands to allow full view of the display assembly.
      Ask FixBot
    3. Leapfrog LeapPad 3 Display Assembly Replacement: step 12, image 1 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 12, image 2 of 3 Leapfrog LeapPad 3 Display Assembly Replacement: step 12, image 3 of 3
      • Remove the display assembly from the black rubber sleeve carefully.
      • There is a specific orientation for the rubber sleeve so take note of its position.
      Ask FixBot
5 other people completed this guide.
Matt Irvine
952 Reputation
6 Guides authored
USF Tampa, Team 16-2, Blackwell Winter 2016 Member of USF Tampa, Team 16-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G2
3 Members
72 Guides authored
4 Guide Comments
Everything worked ok but unit now will not go to home page. after I replaced the display. They tell you necessary tools but never tell you where or how to use the wrist grounding strap.
Dave Alan - Reply Share
Bonjour, j’ai bien réussi à accéder à l’écran,
Ma question:
Oû peut-on se procurer un écran neuf SVP?
Gregory Commarmond - Reply Share
Pouvez vous m'indiquer où trouver un écran de remplacement ?
Merci d'avance
Domi Luky - Reply Share
OK, Visiblement ce tuto ne sert plus à rien car il est Impossible de trouver le display de remplacement!!
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 1,732
