Leapfrog LeapPad 3 Battery Replacement
    1. Leapfrog LeapPad 3 Battery Replacement, Battery: step 1, image 1 of 3 Leapfrog LeapPad 3 Battery Replacement, Battery: step 1, image 2 of 3 Leapfrog LeapPad 3 Battery Replacement, Battery: step 1, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
      • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
      • You will not need to pry the case off.
      Ask FixBot
    2. Leapfrog LeapPad 3 Battery Replacement: step 2, image 1 of 3 Leapfrog LeapPad 3 Battery Replacement: step 2, image 2 of 3 Leapfrog LeapPad 3 Battery Replacement: step 2, image 3 of 3
      • Unplug the battery from the motherboard with your hands.
      • The battery sits to the right of the motherboard.
      Ask FixBot
    3. Leapfrog LeapPad 3 Battery Replacement: step 3, image 1 of 2 Leapfrog LeapPad 3 Battery Replacement: step 3, image 2 of 2
      • Pry the battery gently off of the plastic platform with an opening tool.
      • Do not to puncture the battery, as the material inside can be dangerous.
      Ask FixBot
3 other people completed this guide.
Matt Irvine
952 Reputation
6 Guides authored
USF Tampa, Team 16-2, Blackwell Winter 2016 Member of USF Tampa, Team 16-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G2
3 Members
72 Guides authored
1 Guide Comment
where can i purchase a battery, i have googled and come up with nothing.
martinez2503 - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 46
All Time: 5,084
