Up to 20% off select tools
LeapPad Ultra Battery Replacement
Views: 18K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
140
All Time:
17,680
Comments: 7
3 comments on steps, 4 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
The purpose of this guide is to replace the LeapPad's battery. The battery is essential to receiving any form of functionality from the device. Without a working battery the device is powerless. Once the replacement is finished, be sure to properly dispose of the old battery at appropriate locations such as a batter recycling center.
    1. LeapPad Ultra Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the barcode covering the two screws on the lower back of the Leap Pad.
      Ask FixBot
    2. LeapPad Ultra Battery Replacement: step 2, image 1 of 1
      • Remove the two 5 mm screws that were covered by the sticker.
      Ask FixBot
    3. LeapPad Ultra Battery Replacement: step 3, image 1 of 1
      • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
      Ask FixBot
    4. LeapPad Ultra Battery Replacement: step 4, image 1 of 1
      • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
      Ask FixBot
    5. LeapPad Ultra Battery Replacement: step 5, image 1 of 1
      • Remove the hard plastic casing, exposing the motherboard and battery.
      Ask FixBot
    6. LeapPad Ultra Battery Replacement: step 6, image 1 of 2 LeapPad Ultra Battery Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the battery using tweezers or your fingernails.
      • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
      • Gently pry of the battery lose using a spudger or another thin prying tool.
      • Be careful, damaging/puncturing the battery may cause an explosion.
      Ask FixBot
To reassemble the device, follow these instructions in reverse order.
7 other people completed this guide.
Author
with
Ryan Arredondo
246 Reputation
1 Guide authored
USF Tampa, Team 4-99, Meier Fall 2015 Member of USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 Members
60 Guides authored
4 Guide Comments
Hi Ryan, will removing the battery delete any of the downloaded apps and saved files?
Michael - Reply Share
I’m not Ryan, but I just did this process and the apps and files are all still there.
Kivi Shapiro - Reply Share
What is a spudger and where do I get a battery
P Mac - Reply Share
Hello, if anyone still has this leappad Ultra and wanted to purchase a new battery. I have found a retail store https://batteryclerk.com/ The price is reasonable, and I'm just waiting for the batteries to arrive.
Mike Silva - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 140
All Time: 17,680
