LeapFrog Scribble and Write Motherboard Replacement
  1. LeapFrog Scribble and Write Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
    Ask FixBot
  2. LeapFrog Scribble and Write Motherboard Replacement: step 2, image 1 of 1
    • Remove the back battery cover and all of the batteries.
    Ask FixBot
  3. LeapFrog Scribble and Write Motherboard Replacement: step 3, image 1 of 1
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
    Ask FixBot
  4. LeapFrog Scribble and Write Motherboard Replacement: step 4, image 1 of 1
    • Remove the back cover from your toy.
    Ask FixBot
  5. LeapFrog Scribble and Write Motherboard Replacement: step 5, image 1 of 1
    • Using a Phillips screwdriver, remove the four screws from the motherboard.
    Ask FixBot
  6. LeapFrog Scribble and Write Motherboard Replacement: step 6, image 1 of 1
    • Remove the keyboard ribbon from the motherboard.
    Ask FixBot
  7. LeapFrog Scribble and Write Motherboard Replacement: step 7, image 1 of 1
    • Remove the speaker wires from the motherboard with your soldering iron.
    Ask FixBot
  8. LeapFrog Scribble and Write Motherboard Replacement: step 8, image 1 of 1
    • Remove the battery wires from the motherboard with the soldering iron.
    Ask FixBot
  9. LeapFrog Scribble and Write Motherboard Replacement: step 9, image 1 of 1
    • Remove the switch wires from the motherboard with the soldering iron.
    Ask FixBot
  10. LeapFrog Scribble and Write Motherboard Replacement: step 10, image 1 of 1
    • Remove the pen wires from the motherboard with the soldering iron.
    Ask FixBot
  11. LeapFrog Scribble and Write Motherboard Replacement: step 11, image 1 of 1
    • Remove the volume control switch from the motherboard with the soldering iron.
    Ask FixBot
Shang
328 Reputation
3 Guides authored
USF Tampa, Team 1-5, Nance Spring 2016 Member of USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 1,014
