LeapFrog Scribble and Write Eraser Slider Cleaning
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: step 1, image 1 of 1
    • Turn the toy over so the back is facing upward.
    Ask FixBot
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: step 2, image 1 of 1
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
    Ask FixBot
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: step 3, image 1 of 1
    • Remove the back of the toy by carefully lifting it up.
    Ask FixBot
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: step 4, image 1 of 2 LeapFrog Scribble and Write Eraser Slider Cleaning: step 4, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
    Ask FixBot
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: step 5, image 1 of 1
    • Carefully remove the display screen, leaving the eraser slider attached.
    Ask FixBot
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: step 6, image 1 of 2 LeapFrog Scribble and Write Eraser Slider Cleaning: step 6, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the eraser slider.
    Ask FixBot
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: step 7, image 1 of 1
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    Ask FixBot
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
    Ask FixBot
Shang
328 Reputation
3 Guides authored
USF Tampa, Team 1-5, Nance Spring 2016 Member of USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 58
All Time: 1,092
