LeapFrog LeapTV Controller Joy Stick Replacement
  1. LeapFrog LeapTV Controller Joy Stick Replacement, Battery: step 1, image 1 of 1
    • Use the Metal Spudger to push the release clip on the battery cover.
    Ask FixBot
  2. LeapFrog LeapTV Controller Joy Stick Replacement: step 2, image 1 of 1
    • Lift the cover off.
    Ask FixBot
  3. LeapFrog LeapTV Controller Joy Stick Replacement: step 3, image 1 of 1
    • The battery holder is now visible with the removal of the cover.
    Ask FixBot
  4. LeapFrog LeapTV Controller Joy Stick Replacement, Controller Joy Stick: step 4, image 1 of 1
    • Use the screwdriver to remove the eight 8.7 mm PH1 Phillips head screws.
    Ask FixBot
  5. LeapFrog LeapTV Controller Joy Stick Replacement: step 5, image 1 of 1
    • Separate the top and bottom parts of the controller slightly.
    Ask FixBot
  6. LeapFrog LeapTV Controller Joy Stick Replacement: step 6, image 1 of 1
    • Slide the cover on the back side of the controller covering the joy stick out of the way.
    Ask FixBot
  7. LeapFrog LeapTV Controller Joy Stick Replacement: step 7, image 1 of 1
    • Use the screwdriver to remove the four 8.7 mm PH1 Phillips head screws.
    Ask FixBot
  8. LeapFrog LeapTV Controller Joy Stick Replacement: step 8, image 1 of 1
    • Turn and lift the circuit board with button attacked out of the hole. Do not detach the circuit.
    Ask FixBot
  9. LeapFrog LeapTV Controller Joy Stick Replacement: step 9, image 1 of 1
    • Hold the circuit board and button and pull the button off.
    Ask FixBot
  10. LeapFrog LeapTV Controller Joy Stick Replacement: step 10, image 1 of 1
    • Joystick will now pop off.
    Ask FixBot
Joshua Jones
101 Reputation
1 Guide authored
IUPUI, Team S4-G2, Baechle Spring 2017 Member of IUPUI, Team S4-G2, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G2
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,030
