Up to 20% off select tools
LeapFrog LeapTV Controller Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
90
All Time:
918
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the "A" and "B" buttons on the controller.
    1. LeapFrog LeapTV Controller Button Replacement, Battery: step 1, image 1 of 1
      • Use the Metal Spudger to push the release clip on the battery cover.
      Ask FixBot
    2. LeapFrog LeapTV Controller Button Replacement: step 2, image 1 of 1
      • Lift the cover off.
      Ask FixBot
    3. LeapFrog LeapTV Controller Button Replacement: step 3, image 1 of 1
      • The battery holder is now visible with the removal of the cover.
      Ask FixBot
    1. LeapFrog LeapTV Controller Button Replacement, Buttons: step 4, image 1 of 1
      • Use the screwdriver to remove the eight 8.7mm PH1 Phillips head screws.
      Ask FixBot
    2. LeapFrog LeapTV Controller Button Replacement: step 5, image 1 of 1
      • Slightly lift up on the back cover until the handle covers are free to rotate.
      Ask FixBot
    3. LeapFrog LeapTV Controller Button Replacement: step 6, image 1 of 1
      • Slide the the side of the handle facing you to the left to reveal the "A" and "B" button circuit board.
      Ask FixBot
    4. LeapFrog LeapTV Controller Button Replacement: step 7, image 1 of 1
      • Use the screwdriver to remove the three 8.5mm PH1 Phillips head screws.
      Ask FixBot
    5. LeapFrog LeapTV Controller Button Replacement: step 8, image 1 of 1
      • Lift up on the circuit board and move it to the side.
      • Be careful to not cause excess stress to the connecting wires when handling the circuit board. Excess stress can cause solder points to break.
      Ask FixBot
    6. LeapFrog LeapTV Controller Button Replacement: step 9, image 1 of 1
      • Use the plastic opening tool to release the buttons from the controller casing.
      Ask FixBot
    7. LeapFrog LeapTV Controller Button Replacement: step 10, image 1 of 1
      • Remove the "A" and "B" buttons by pulling up on one of the buttons.
      Ask FixBot
    8. LeapFrog LeapTV Controller Button Replacement: step 11, image 1 of 1
      • Buttons are now removed.
      Ask FixBot
2 other people completed this guide.
Author
with
Triston Fischer
152 Reputation
1 Guide authored
IUPUI, Team S4-G2, Baechle Spring 2017 Member of IUPUI, Team S4-G2, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 90
All Time: 918
