LeapFrog LeapPad2 Explorer Screen Replacement
Views: 71K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
112
All Time:
70,922
Comments: 20
1 comment on steps, 19 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your LeapFrog LeapPad2 Explorer screen is cracked or damaged, follow this guide to replace it. Be sure to power off the device prior to beginning the guide.
This guide will require soldering equipment and skill.
Tools
    1. LeapFrog LeapPad2 Explorer Screen Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad2 Explorer Screen Replacement, Battery: step 1, image 2 of 2
      • Before disassembling your LeapPad, ensure your device is shut off.
      • Push outward on the plastic side panels to remove and reveal battery.
      • The panels should detach fully from the main device.
      Ask FixBot
    2. LeapFrog LeapPad2 Explorer Screen Replacement: step 2, image 1 of 3 LeapFrog LeapPad2 Explorer Screen Replacement: step 2, image 2 of 3 LeapFrog LeapPad2 Explorer Screen Replacement: step 2, image 3 of 3
      • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
      • Remove all four AA alkaline batteries from the device.
      Ask FixBot
    1. LeapFrog LeapPad2 Explorer Screen Replacement, Back Cover: step 3, image 1 of 2 LeapFrog LeapPad2 Explorer Screen Replacement, Back Cover: step 3, image 2 of 2
      • This step will void your device warranty.
      • Remove the following screws securing the back cover to the main device:
      • Two 10.0 mm Phillips screws
      • Four 4.0 mm Phillips screws
      • Three 3.0 mm Phillips screws
      Ask FixBot
    2. LeapFrog LeapPad2 Explorer Screen Replacement: step 4, image 1 of 3 LeapFrog LeapPad2 Explorer Screen Replacement: step 4, image 2 of 3 LeapFrog LeapPad2 Explorer Screen Replacement: step 4, image 3 of 3
      • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
      • Move the plastic opening tool around the perimeter of the LeapPad2.
      • Lift up and remove the rear case from the tablet.
      • A butter knife can help when prying the device.
      Ask FixBot
    1. LeapFrog LeapPad2 Explorer Screen Replacement, Front Cover: step 5, image 1 of 2 LeapFrog LeapPad2 Explorer Screen Replacement, Front Cover: step 5, image 2 of 2
      • Remove the following screws securing the front cover to the main device:
      • Three 6.0 mm Phillips screws
      • Three 7.0 mm Phillips screws
      • Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
      • The white plastic component holding the speaker must be removed to reach the third 7.0 mm Phillips screw. Refer to Step 2.
      Ask FixBot
    2. LeapFrog LeapPad2 Explorer Screen Replacement: step 6, image 1 of 2 LeapFrog LeapPad2 Explorer Screen Replacement: step 6, image 2 of 2
      • Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned.
      Ask FixBot
    3. LeapFrog LeapPad2 Explorer Screen Replacement: step 7, image 1 of 2 LeapFrog LeapPad2 Explorer Screen Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • When unscrewing the game cartridge screws, you will find a loose black plastic component underneath the game cartridge.
      • Use tweezers to remove the piece.
      • In case the piece falls out unexpectedly, refer to this step to make sure you put this piece back in place during the reassembly of your device.
      Ask FixBot
    4. LeapFrog LeapPad2 Explorer Screen Replacement: step 8, image 1 of 2 LeapFrog LeapPad2 Explorer Screen Replacement: step 8, image 2 of 2
      • Desolder the through hole-components in power plugs on both sides of the device where the batteries were once connected.
      • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
      • For proper soldering and desoldering techniques reference How To Solder and Desolder Connections.
      • Soldering requires the iron to be at hot temperatures and can cause burns. Wear safety glasses as needed.
      • Be extremely careful with the cables in this step as they could melt, burn, or break.
      Ask FixBot
    5. LeapFrog LeapPad2 Explorer Screen Replacement: step 9, image 1 of 2 LeapFrog LeapPad2 Explorer Screen Replacement: step 9, image 2 of 2
      • Pry the power cables from the device using your fingers or tweezers.
      • Now you should be able to lift up the front cover, leaving you with the motherboard and screen.
      Ask FixBot
    1. LeapFrog LeapPad2 Explorer Screen Replacement, Screen: step 10, image 1 of 3 LeapFrog LeapPad2 Explorer Screen Replacement, Screen: step 10, image 2 of 3 LeapFrog LeapPad2 Explorer Screen Replacement, Screen: step 10, image 3 of 3
      • Lift the screen from the motherboard by pushing the board out from the three metal tabs.
      • Do not be too aggressive when separating the components, as the parts are still connected.
      Ask FixBot
    2. LeapFrog LeapPad2 Explorer Screen Replacement: step 11, image 1 of 1
      • Fold screen away from the motherboard along the yellow ribbon, lay the device's components flat open like a book.
      Ask FixBot
    3. LeapFrog LeapPad2 Explorer Screen Replacement: step 12, image 1 of 1
      • Gently remove the tape covering the yellow ribbon connecting screen to motherboard.
      Ask FixBot
    4. LeapFrog LeapPad2 Explorer Screen Replacement: step 13, image 1 of 1
      • To safely remove yellow ribbon, lift up the retaining flap.
      • Removing or reinserting the cable by brute force could damage it.
      Ask FixBot
    5. LeapFrog LeapPad2 Explorer Screen Replacement: step 14, image 1 of 1
      • Pull the yellow ribbon towards the screen to disconnect the screen from the socket on the motherboard.
      • If the flap is up, as show in the picture, no force should be required to remove the cable.
      Ask FixBot
11 other people completed this guide.
Nupur Garg
867 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2014 Member of Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Members
108 Guides authored
19 Guide Comments
where do you get a new screen from????
Paula Leflar - Reply Share
We got one on eBay. It was actually a LeapPad (original, not a LeapPad 2 Explorer) that would not boot. I figured the screen would be ok, even if the logic board was bad, and it turned out to be true. Our LeapPad 2 Explorer now works great. Bit of a pain moving the screen assembly from the old model to the new one, but it fits fine and works perfectly.
Jeremiah - Reply Share
Where do you get a new screen from ??? Please help!
Carmen Nida - Reply Share
where can I get a screen for the leappad2?
sophia - Reply Share
No need to desolder positive battery terminals... (on step 8)
They pull straight up just like the negative terminals just a bit tighter..
Easiest way to do this is by using a small diameter screw driver... pass it under the upper metal bend of positive contact and pull straight up..
SiRaDuDe - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 112
All Time: 70,922
