LeapFrog LeapPad2 Explorer Back Cover Replacement
    1. LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: step 1, image 2 of 2
      • Before disassembling your LeapPad, ensure your device is shut off.
      • Push outward on the plastic side panels to remove and reveal battery.
      • The panels should detach fully from the main device.
      Ask FixBot
    2. LeapFrog LeapPad2 Explorer Back Cover Replacement: step 2, image 1 of 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: step 2, image 2 of 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: step 2, image 3 of 3
      • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
      • Remove all four AA alkaline batteries from the device.
      Ask FixBot
    1. LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: step 3, image 1 of 2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: step 3, image 2 of 2
      • This step will void your device warranty.
      • Remove the following screws securing the back cover to the main device:
      • Two 10.0 mm Phillips screws
      • Four 4.0 mm Phillips screws
      • Three 3.0 mm Phillips screws
      Ask FixBot
    2. LeapFrog LeapPad2 Explorer Back Cover Replacement: step 4, image 1 of 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: step 4, image 2 of 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: step 4, image 3 of 3
      • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
      • Move the plastic opening tool around the perimeter of the LeapPad2.
      • Lift up and remove the rear case from the tablet.
      • A butter knife can help when prying the device.
      Ask FixBot
Nupur Garg
867 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2014 Member of Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 22
All Time: 1,819
