LeapFrog LeapPad2 Explorer Back Camera Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
78
All Time:
1,678
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide in order to capture the essence of replacing your back camera, enabling you to capture the world!
Tools
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: step 1, image 2 of 2
      • Before disassembling your LeapPad, ensure your device is shut off.
      • Push outward on the plastic side panels to remove and reveal battery.
      • The panels should detach fully from the main device.
      Ask FixBot
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 2, image 1 of 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 2, image 2 of 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 2, image 3 of 3
      • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
      • Remove all four AA alkaline batteries from the device.
      Ask FixBot
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: step 3, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: step 3, image 2 of 2
      • This step will void your device warranty.
      • Remove the following screws securing the back cover to the main device:
      • Two 10.0 mm Phillips screws
      • Four 4.0 mm Phillips screws
      • Three 3.0 mm Phillips screws
      Ask FixBot
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 4, image 1 of 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 4, image 2 of 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 4, image 3 of 3
      • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
      • Move the plastic opening tool around the perimeter of the LeapPad2.
      • Lift up and remove the rear case from the tablet.
      • A butter knife can help when prying the device.
      Ask FixBot
    1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: step 5, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: step 5, image 2 of 2
      • Locate the back camera below the game cartridge.
      Ask FixBot
    2. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 6, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 6, image 2 of 2
      • To safely remove the ribbon cable, first you must pull up the retaining flap.
      • Removing or reinserting the cable by brute force can damage it.
      Ask FixBot
    3. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 7, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 7, image 2 of 2
      • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
      Ask FixBot
    4. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 8, image 1 of 1
      • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
      Ask FixBot
Nupur Garg
867 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2014 Member of Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 78
All Time: 1,678
