LeapFrog LeapPad Ultra XDi Screen Replacement
  1. LeapFrog LeapPad Ultra XDi Screen Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad Ultra XDi Screen Replacement, Battery: step 1, image 2 of 2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
    Ask FixBot
  2. LeapFrog LeapPad Ultra XDi Screen Replacement: step 2, image 1 of 2 LeapFrog LeapPad Ultra XDi Screen Replacement: step 2, image 2 of 2
    • Remove the two 5.0mm Phillips #0 screws.
    Ask FixBot
  3. LeapFrog LeapPad Ultra XDi Screen Replacement: step 3, image 1 of 3 LeapFrog LeapPad Ultra XDi Screen Replacement: step 3, image 2 of 3 LeapFrog LeapPad Ultra XDi Screen Replacement: step 3, image 3 of 3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
    Ask FixBot
  4. LeapFrog LeapPad Ultra XDi Screen Replacement: step 4, image 1 of 2 LeapFrog LeapPad Ultra XDi Screen Replacement: step 4, image 2 of 2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
    Ask FixBot
  5. LeapFrog LeapPad Ultra XDi Screen Replacement: step 5, image 1 of 2 LeapFrog LeapPad Ultra XDi Screen Replacement: step 5, image 2 of 2
    • Remove the purple case, exposing the motherboard and battery.
    Ask FixBot
  6. LeapFrog LeapPad Ultra XDi Screen Replacement: step 6, image 1 of 3 LeapFrog LeapPad Ultra XDi Screen Replacement: step 6, image 2 of 3 LeapFrog LeapPad Ultra XDi Screen Replacement: step 6, image 3 of 3
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Use the Spudger to remove the glued down battery.
    Ask FixBot
  7. LeapFrog LeapPad Ultra XDi Screen Replacement, Screen: step 7, image 1 of 3 LeapFrog LeapPad Ultra XDi Screen Replacement, Screen: step 7, image 2 of 3 LeapFrog LeapPad Ultra XDi Screen Replacement, Screen: step 7, image 3 of 3
    • Locate the two ribbon cables on top of the motherboard.
    • Flip up the locking clip on the ribbon cable connector to release the cable.
    • Disconnect the cables from their connectors.
    Ask FixBot
  8. LeapFrog LeapPad Ultra XDi Screen Replacement: step 8, image 1 of 1
    • Unscrew the four 5.0 mm Phillips #0 screws securing the motherboard.
    Ask FixBot
  9. LeapFrog LeapPad Ultra XDi Screen Replacement: step 9, image 1 of 3 LeapFrog LeapPad Ultra XDi Screen Replacement: step 9, image 2 of 3 LeapFrog LeapPad Ultra XDi Screen Replacement: step 9, image 3 of 3
    • Pull the two side grips up to remove them from the casing.
    • Unscrew the eight 7.0 mm Phillips #1 screws securing the base. Remove the base.
    Ask FixBot
  10. LeapFrog LeapPad Ultra XDi Screen Replacement: step 10, image 1 of 2 LeapFrog LeapPad Ultra XDi Screen Replacement: step 10, image 2 of 2
    • Unscrew the eleven 7.0 mm Phillips #1 screws securing the circuit board to the case. Remove the circuit board.
    Ask FixBot
  11. LeapFrog LeapPad Ultra XDi Screen Replacement: step 11, image 1 of 1
    • Lift the screen from the front case. Replace the screen.
    Ask FixBot
2 Guide Comments
Where exactly can I find a replacement screen? I have looked everywhere with no luck.
Siblings have a cracked one i would really like to fix so any help would be greatly appreciated.
Derp Dude - Reply Share
So I would suggest ebay or buy one that's not chargable on macari and use it for parts that's the route I'm taking with what ever I find .hope that helps since this post is old
Cherry - Reply Share
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 41
All Time: 1,626
