LeapFrog LeapPad Ultra XDi Home Button Replacement
    1. LeapFrog LeapPad Ultra XDi Home Button Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad Ultra XDi Home Button Replacement, Battery: step 1, image 2 of 2
      • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
      • Remove the barcode sticker to expose the two screws.
      Ask FixBot
    2. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 2, image 1 of 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 2, image 2 of 2
      • Remove the two 5.0mm Phillips #0 screws.
      Ask FixBot
    3. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 3, image 1 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 3, image 2 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 3, image 3 of 3
      • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
      Ask FixBot
    4. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 4, image 1 of 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 4, image 2 of 2
      • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
      Ask FixBot
    5. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 5, image 1 of 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 5, image 2 of 2
      • Remove the purple case, exposing the motherboard and battery.
      Ask FixBot
    6. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 6, image 1 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 6, image 2 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 6, image 3 of 3
      • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
      • Use the Spudger to remove the glued down battery.
      Ask FixBot
    1. LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: step 7, image 1 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: step 7, image 2 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: step 7, image 3 of 3
      • Locate the three ribbon cables on top of the motherboard.
      • Flip up the locking clip on the ribbon cable connector to release the cable.
      • Disconnect the cables from their connectors.
      Ask FixBot
    2. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 8, image 1 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 8, image 2 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 8, image 3 of 3
      • Unscrew the four 5mm Phillips #1 screws.
      • Unscrew the two 5mm Phillips #1 screws.
      • Lift the home button circuit board up. Replace the home button circuit board.
      • The entire home button circuit board must be replaced.
      • Do not dispose of rubber padding on home button circuit board.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 27
All Time: 577
