Leader Impression i10A-LE Microphone Replacement
    1. Leader Impression i10A-LE Microphone Replacement, Microphone: step 1, image 1 of 1
      • Orient your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
      Ask FixBot
    2. Leader Impression i10A-LE Microphone Replacement: step 2, image 1 of 3 Leader Impression i10A-LE Microphone Replacement: step 2, image 2 of 3 Leader Impression i10A-LE Microphone Replacement: step 2, image 3 of 3
      • Pry the back off by using plastic opening tools.
      • Using the plastic tools slide the flat end into the device.
      • Gently pry the back piece until you hear a popping noise.
      • Once the back is loose, remove it from the device and set aside.
      Ask FixBot
    3. Leader Impression i10A-LE Microphone Replacement: step 3, image 1 of 2 Leader Impression i10A-LE Microphone Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the positive and negative battery leads.
      • Remove the microphone from plastic housing with the tweezers.
      • Desolder the positive (red) and negative (black) power leads.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 321
