Leader Impression i10A-LE Battery Pack Replacement
    1. Leader Impression i10A-LE Battery Pack Replacement, Battery Pack: step 1, image 1 of 1
      • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
      Ask FixBot
    2. Leader Impression i10A-LE Battery Pack Replacement: step 2, image 1 of 3 Leader Impression i10A-LE Battery Pack Replacement: step 2, image 2 of 3 Leader Impression i10A-LE Battery Pack Replacement: step 2, image 3 of 3
      • Use the plastic prying tools to crack open the back of the device.
      • Once cracked, use more plastic prying tools to fully remove the back panel. A popping noise will occur when each clip is opened.
      • Remove the back panel and set aside.
      Ask FixBot
    3. Leader Impression i10A-LE Battery Pack Replacement: step 3, image 1 of 2 Leader Impression i10A-LE Battery Pack Replacement: step 3, image 2 of 2
      • The battery pack is glued to the device.
      • Use a spudger to pry the battery pack from the glue.
      • Desolder the positive (red) and negative (black) power leads.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 21
Past 30 Days: 35
All Time: 820
