Leader Impression i10A-LE Back Facing Camera Replacement
    1. Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: step 1, image 1 of 2 Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: step 1, image 2 of 2
      • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
      Ask FixBot
    2. Leader Impression i10A-LE Back Facing Camera Replacement: step 2, image 1 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 2, image 2 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 2, image 3 of 3
      • Start by prying the back off by using plastic opening tools.
      • Using the plastic tools slide the flat end into the device.
      • Gently pry the back piece until you hear a popping noise.
      • Once the back is loose, remove it from the device and set aside.
      Ask FixBot
    3. Leader Impression i10A-LE Back Facing Camera Replacement: step 3, image 1 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 3, image 2 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Once the back is off, locate the back facing camera.
      • The camera will be in the top left corner.
      • Using the precision tweezers that are bent, gently grab the strip below the camera.
      • slowly lift up until the camera lifts from its spot.
      Ask FixBot
    4. Leader Impression i10A-LE Back Facing Camera Replacement: step 4, image 1 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 4, image 2 of 3 Leader Impression i10A-LE Back Facing Camera Replacement: step 4, image 3 of 3
      • Continue slowly lifting with the bent precision tweezers.
      • The bottom half of the camera strip will pop out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 502
