Up to 20% off select tools
Le Pan S Screen Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
86
All Time:
1,851
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Very difficult
Tools
Introduction
Go to step 1 ↓
In this guide, you will be instructed step-by-step through the replacement process of your broken Le Pan S screen. Please note that this screen is attached to the plastic casing using adhesives and will require special attention during the steps outlined below. The LCD display will be removed first in order to prevent potential damage to the parts. Pay careful attention when using the heat gun or blow dryer in order to avoid skin burns.
    1. Le Pan S Screen Replacement, Battery: step 1, image 1 of 1
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      Ask FixBot
    2. Le Pan S Screen Replacement: step 2, image 1 of 2 Le Pan S Screen Replacement: step 2, image 2 of 2
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      Ask FixBot
    3. Le Pan S Screen Replacement: step 3, image 1 of 1
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      Ask FixBot
    4. Le Pan S Screen Replacement: step 4, image 1 of 2 Le Pan S Screen Replacement: step 4, image 2 of 2
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      Ask FixBot
    1. Le Pan S Screen Replacement, Screen: step 5, image 1 of 1
      • Remove the tape covering the end of the flat ribbon cable.
      Ask FixBot
    2. Le Pan S Screen Replacement: step 6, image 1 of 2 Le Pan S Screen Replacement: step 6, image 2 of 2
      • Disconnect the display cable connector by gently pulling the white connection head out of its base.
      • Repeat for the cable's other end attached near the top of the tablet.
      Ask FixBot
    3. Le Pan S Screen Replacement: step 7, image 1 of 1
      • Disconnect the flat ribbon cable by disconnecting the zero insertion force (ZIF) connector.
      • This can be done by using a plastic opening tool, spudger, or fingernail to lift the retaining flap.
      Ask FixBot
    4. Le Pan S Screen Replacement: step 8, image 1 of 1
      • Remove the six 2.5 mm Phillips #00 screws securing the green electrical board.
      Ask FixBot
    5. Le Pan S Screen Replacement: step 9, image 1 of 1
      • Use the spudger to remove the vibration controller.
      Ask FixBot
    6. Le Pan S Screen Replacement: step 10, image 1 of 1
      • Remove the four 3.5 mm Phillips #00 screws holding the speakers in place.
      Ask FixBot
    7. Le Pan S Screen Replacement: step 11, image 1 of 2 Le Pan S Screen Replacement: step 11, image 2 of 2
      • Flip the green electrical board back so that the screen is separated from the green board.
      • Be careful not to break the Wi-Fi antenna cable that is still soldered to the plastic casing.
      Ask FixBot
    8. Le Pan S Screen Replacement: step 12, image 1 of 1
      • Remove the seven 3.5 mm Phillips #00 screws that connect the grey backing to the screen.
      Ask FixBot
    9. Le Pan S Screen Replacement: step 13, image 1 of 2 Le Pan S Screen Replacement: step 13, image 2 of 2
      • Take the gray backing off of the screen so that only the back of the LCD display is showing.
      Ask FixBot
    10. Le Pan S Screen Replacement: step 14, image 1 of 1
      • Remove the LCD display by lifting up carefully.
      • Place the display in an area where it will not be damaged.
      Ask FixBot
    11. Le Pan S Screen Replacement: step 15, image 1 of 1
      • Flip the device over to the front.
      • Use a heat gun or hairdryer to help loosen any adhesive present on the screen. Start with a low, evenly applied heat and slowly increase the temperature as needed.
      • If you do not have a heat gun or hairdryer, use the metal opening tools mentioned in Step 16.
      • Use the plastic spudger and the plastic opening tool to prop the screen off of the adhesive at one corner.
      Ask FixBot
    12. Le Pan S Screen Replacement: step 16, image 1 of 1
      • Slide the metal opening tools across the sides of the screen in order to separate the adhesive away from the screen.
      • Continue this process until all the sides of the screen are disconnected from the Le Pan S.
      • Make sure to scrape off any remaining adhesive from the housing before adding the new screen and adhesive.
      Ask FixBot
Author
with
Maria Dole
395 Reputation
3 Guides authored
IUPUI, Team 2-1, Harley Fall 2015 Member of IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 Members
60 Guides authored
1 Guide Comment
Where can I find the replacement display screen for my Lepan TC802a tablet.
James
jrmpr@aol.com
James - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 86
All Time: 1,851
