Up to 20% off select tools
Lasko CD08200 Control Panel Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
73
All Time:
1,366
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The panel is a curved component that is part of the outer covering of a device. A faulty panel can cause your Lasko CD08200 heater to be exposed to outside sources such as water which can lead to unfortunate incidents. In some cases, your heater may not work at all if it has a faulty panel.
 Before using this guide, make sure to review the troubleshooting page to be sure if replacing the control panel is the correct action to fix your device.
    1. Lasko CD08200 Control Panel Replacement, Lasko CD08200 Disassembly: step 1, image 1 of 2 Lasko CD08200 Control Panel Replacement, Lasko CD08200 Disassembly: step 1, image 2 of 2
      • Turn over the device and place it on its head.
      • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
      Ask FixBot
    2. Lasko CD08200 Control Panel Replacement: step 2, image 1 of 1
      • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
      • Remove the power cord casing from the device case.
      Ask FixBot
    3. Lasko CD08200 Control Panel Replacement: step 3, image 1 of 3 Lasko CD08200 Control Panel Replacement: step 3, image 2 of 3 Lasko CD08200 Control Panel Replacement: step 3, image 3 of 3
      • Cut the sticker on the right side of the device using a Jimmy.
      • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
      • If your screwdriver cannot reach the screw, you can use the metal spudger.
      • Remove the back casing from the device.
      Ask FixBot
    4. Lasko CD08200 Control Panel Replacement: step 4, image 1 of 3 Lasko CD08200 Control Panel Replacement: step 4, image 2 of 3 Lasko CD08200 Control Panel Replacement: step 4, image 3 of 3
      • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
      • Remove the top of the fan housing with the fan attached and place it on the table.
      Ask FixBot
    1. Lasko CD08200 Control Panel Replacement, Control Panel: step 5, image 1 of 2 Lasko CD08200 Control Panel Replacement, Control Panel: step 5, image 2 of 2
      • Unscrew the four rings using the Phillips #2.
      • Gently remove the fan base from the device.
      Ask FixBot
    2. Lasko CD08200 Control Panel Replacement: step 6, image 1 of 3 Lasko CD08200 Control Panel Replacement: step 6, image 2 of 3 Lasko CD08200 Control Panel Replacement: step 6, image 3 of 3
      • Remove the four 14mm screws using the Phillips #2 screwdriver.
      • Gently detach the control panel from the device.
      Ask FixBot
    3. Lasko CD08200 Control Panel Replacement: step 7, image 1 of 2 Lasko CD08200 Control Panel Replacement: step 7, image 2 of 2
      • Remove the five 14mm screws using the Phillips #2 screwdriver.
      • Pull apart the motherboard from the panel.
      Ask FixBot
    4. Lasko CD08200 Control Panel Replacement: step 8, image 1 of 3 Lasko CD08200 Control Panel Replacement: step 8, image 2 of 3 Lasko CD08200 Control Panel Replacement: step 8, image 3 of 3
      • Remove the three 10mm screws using the Phillips #2 screwdriver.
      • Pull the button from the panel’s top.
      • During reassembly of the top panel, you must align the LED light with the three windows of the top panel and back panel.
      Ask FixBot
Author
with
Najiib Ahmed
161 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 73
All Time: 1,366
