Up to 20% off select tools
Lasko Box Fan Back Wire Repair
Views: 25K
View statistics:
Past 24 Hours:
9
Past 7 Days:
36
Past 30 Days:
144
All Time:
25,001
Comments: 10
2 comments on steps, 8 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Over time, the wire that runs up the back of the fan behind the blades may come into contact with the blades, and become damaged or severed. This guide is meant to show how to repair the damage.
    1. Lasko Box Fan Back Wire Repair, Lasko Box Fan Back Wire Repair: step 1, image 1 of 3 Lasko Box Fan Back Wire Repair, Lasko Box Fan Back Wire Repair: step 1, image 2 of 3 Lasko Box Fan Back Wire Repair, Lasko Box Fan Back Wire Repair: step 1, image 3 of 3
      • Make sure the fan is unplugged.
      • Unscrew the 6 screws on the front of the fan.
      • Remove the face plate.
      • Flip the fan and repeat for the 6 screws on the back. They are in the same position as the front.
      Ask FixBot
    2. Lasko Box Fan Back Wire Repair: step 2, image 1 of 2 Lasko Box Fan Back Wire Repair: step 2, image 2 of 2
      • Unscrew the screws attaching the motor/blades to the frame.
      • Unscrew the screws attaching the plastic frame to the motor.
      • The blades cannot be removed from the motor.
      Ask FixBot
    3. Lasko Box Fan Back Wire Repair: step 3, image 1 of 2 Lasko Box Fan Back Wire Repair: step 3, image 2 of 2
      • Strip the wires using wire strippers.
      Ask FixBot
    4. Lasko Box Fan Back Wire Repair: step 4, image 1 of 1
      • Twist the ends of the wire together
      • Place wires in soldering kit arms.
      Ask FixBot
    5. Lasko Box Fan Back Wire Repair: step 5, image 1 of 2 Lasko Box Fan Back Wire Repair: step 5, image 2 of 2
      • Plug in the soldering iron.
      • When the soldering iron is hot, solder the wires together.
      • Place the tip of the soldering iron on the wires directly.
      • Place the solder on the wire.
      • Remove the solder and soldering iron from the wire
      • Repeat this step with the second wire.
      • Soldering irons are very hot!
      Ask FixBot
    6. Lasko Box Fan Back Wire Repair: step 6, image 1 of 3 Lasko Box Fan Back Wire Repair: step 6, image 2 of 3 Lasko Box Fan Back Wire Repair: step 6, image 3 of 3
      • Use electrical tape to insulate the wires.
      • Wrap the tape around each wire.
      • Wrap tape around the outside of all of the wires.
      • Make sure to completely cover any exposed wire.
      Ask FixBot
    7. Lasko Box Fan Back Wire Repair: step 7, image 1 of 2 Lasko Box Fan Back Wire Repair: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Clean out the dust from the blades and motor using tweezers.
      Ask FixBot
    8. Lasko Box Fan Back Wire Repair: step 8, image 1 of 3 Lasko Box Fan Back Wire Repair: step 8, image 2 of 3 Lasko Box Fan Back Wire Repair: step 8, image 3 of 3
      • Tape wires along the frame to prevent further damage.
      • Put the face plates back on and enjoy!
      Ask FixBot
3 other people completed this guide.
Author
with
Zach Emard
227 Reputation
1 Guide authored
Cal Poly, Team 14-1, Green Fall 2015 Member of Cal Poly, Team 14-1, Green Fall 2015
CPSU-GREEN-F15S14G1
4 Members
48 Guides authored
8 Guide Comments
Any tips for replacing the "Blue Plug" fuse after it's mysteriously blown in a Lasko box fan?
https://www.amazon.com/fused-safety-Lask...
I could hillbilly wire up a new plug to minimize the wire work, but don't want to start a fire either.
Zac Appleton - Reply Share
I would also like to know how to replace the plug end after the non-replaceable fuse inside the plug is blown.
Gung Ho - Reply Share
I don't know bout you but I was able to “pop" my fan blades right off of motor. Now I'm just going to replace plug end and see if it'll work since fixing wires didn't help.
(Yep found fuse was blown. Why would they make the fuse non replaceable when they eventually blow? Wonder how many fans people have thrown out all because of a blown fuse??
Steff Lusher - Reply Share
That's exactly why it is non replaceable..
Throw it away and buy a NEW one.
2nd Son Home Services - Reply Share
Not one thing worked
zakkerycastine876 - Reply Share
Past 24 Hours: 9
Past 7 Days: 36
Past 30 Days: 144
All Time: 25,001
