Lasko B20200 Rotor Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
107
All Time:
944
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your floor fan is not spinning properly or making unusual noises, this guide will help you repair it by replacing the rotor. A damaged rotor can cause reduced airflow, overheating, or complete fan failure. Before starting, check for any loose screws, dust buildup, or obstructions in the blades. Make sure to unplug the fan before beginning the repair process.
Unplug the fan from any power source before starting the repair to avoid electric shock.
Some internal components may have sharp edges. Handle parts carefully to prevent injury.
Parts
Tools
    1. Lasko B20200 Rotor Replacement, Rotor Replacement: step 1, image 1 of 3 Lasko B20200 Rotor Replacement, Rotor Replacement: step 1, image 2 of 3 Lasko B20200 Rotor Replacement, Rotor Replacement: step 1, image 3 of 3
      • Remove the six 1.5 mm Phillips #1 screws on both sides of the fan.
      • Gently push both side covers upward while applying light pressure to remove the fan guard.
      Ask FixBot
    2. Lasko B20200 Rotor Replacement: step 2, image 1 of 2 Lasko B20200 Rotor Replacement: step 2, image 2 of 2
      • Lift the fan blade assembly directly up and off the rotor.
      Ask FixBot
    3. Lasko B20200 Rotor Replacement: step 3, image 1 of 2 Lasko B20200 Rotor Replacement: step 3, image 2 of 2
      • Remove the four 1.5 mm Phillips #1 screws securing the rotor cover.
      Ask FixBot
    4. Lasko B20200 Rotor Replacement: step 4, image 1 of 2 Lasko B20200 Rotor Replacement: step 4, image 2 of 2
      • Turn the fan over to access the back of the frame.
      • Remove the four 1.5 mm Phillips #1 screws securing the rotor to the frame.
      • Lift the cover off the rotor.
      Ask FixBot
    5. Lasko B20200 Rotor Replacement: step 5, image 1 of 3 Lasko B20200 Rotor Replacement: step 5, image 2 of 3 Lasko B20200 Rotor Replacement: step 5, image 3 of 3
      • Remove the four 1.5 mm screws that secure the rotor cover.
      • Remove the rotor cover.
      Ask FixBot
    6. Lasko B20200 Rotor Replacement: step 6, image 1 of 3 Lasko B20200 Rotor Replacement: step 6, image 2 of 3 Lasko B20200 Rotor Replacement: step 6, image 3 of 3
      • Carefully detach and remove the old rotor.
      • Place the new rotor inside.
      • Align it properly and secure it with the screws.
      Ask FixBot
    7. Lasko B20200 Rotor Replacement: step 7, image 1 of 2 Lasko B20200 Rotor Replacement: step 7, image 2 of 2
      • Ensure both arrows on the front and back of the rotor are aligned correctly for proper reassembly.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Double-check that all screws are securely fastened. Plug in the fan and test it to ensure smooth operation. If the fan does not function properly, inspect the assembly and make sure all parts are correctly aligned and secured.
Khalil
145 Reputation
1 Guide authored
Cooperators Member of Cooperators
Community
20 Members
408 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 107
All Time: 944
