Up to 20% off select tools
Lasergrip 1080 Sensor Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
104
All Time:
2,423
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show how to disconnect the sensor from the motherboard for replacement or repair. This guide is necessary if the device will not read any temperatures or is reading incorrect temperatures. The tools required are a screwdriver and soldering iron. Because a soldering iron presents a hazard, there is a link to a soldering guide in the Troubleshooting section of the device page.
    1. Lasergrip 1080 Sensor Replacement, Battery: step 1, image 1 of 1
      • Pull the battery cover away from the handle by gripping near the thumb groove.
      Ask FixBot
    2. Lasergrip 1080 Sensor Replacement: step 2, image 1 of 1
      • Gently pull the battery out of the handle.
      • Excessive force could damage wires.
      Ask FixBot
    3. Lasergrip 1080 Sensor Replacement: step 3, image 1 of 2 Lasergrip 1080 Sensor Replacement: step 3, image 2 of 2
      • Disconnect the battery by pulling the connector away from it.
      • Positive first
      • Negative second
      • When replacing the battery, this order is reversed.
      Ask FixBot
    1. Lasergrip 1080 Sensor Replacement, Buttons: step 4, image 1 of 2 Lasergrip 1080 Sensor Replacement, Buttons: step 4, image 2 of 2
      • Remove the battery cover from the device by pulling it straight out.
      Ask FixBot
    2. Lasergrip 1080 Sensor Replacement: step 5, image 1 of 2 Lasergrip 1080 Sensor Replacement: step 5, image 2 of 2
      • Using the plastic opening tool remove the front and rear yellow covers.
      • When removing the back cover, be careful not to lose the buttons as they are not connected.
      Ask FixBot
    3. Lasergrip 1080 Sensor Replacement: step 6, image 1 of 1
      • Remove the two 3.1 mm Phillips #0 screws.
      Ask FixBot
    4. Lasergrip 1080 Sensor Replacement: step 7, image 1 of 2 Lasergrip 1080 Sensor Replacement: step 7, image 2 of 2
      • Pull the two halves apart.
      • Be careful not to lose any components on the inside.
      Ask FixBot
    5. Lasergrip 1080 Sensor Replacement: step 8, image 1 of 1
      • Realign the buttons with the button terminals.
      • Red terminal to red button.
      • Orange terminal to orange button.
      • Yellow terminal to yellow button.
      Ask FixBot
    1. Lasergrip 1080 Sensor Replacement, Etekcity Lasergrip 1080 Trigger Replacement: step 9, image 1 of 2 Lasergrip 1080 Sensor Replacement, Etekcity Lasergrip 1080 Trigger Replacement: step 9, image 2 of 2
      • Carefully pull the trigger out.
      • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
      • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
      Ask FixBot
    1. Lasergrip 1080 Sensor Replacement, Sensor: step 10, image 1 of 1
      • Pull the motherboard out of its slot in the device.
      Ask FixBot
    2. Lasergrip 1080 Sensor Replacement: step 11, image 1 of 1
      • Using a soldering iron, melt the solder that holds the wires for the sensor to the motherboard.
      • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
      Ask FixBot
Author
with
Carlos Lewis
162 Reputation
1 Guide authored
USF Tampa, Team 5-1, Blackwell Fall 2015 Member of USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 104
All Time: 2,423
