Large Animal Water Nipple Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
83
All Time:
773
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This is a replacement of a large animal water nipple, this will provide them access to water without them making a huge mess. This guide has ten easy to follow steps to ensure the replacement is done properly.
Tools
    1. Large Animal Water Nipple Replacement, Large Animal Water Nipple: step 1, image 1 of 1
      • Empty the container of all water.
      Ask FixBot
    2. Large Animal Water Nipple Replacement: step 2, image 1 of 1
      • With an adjustable wrench, unscrew the nut on the inside located near the base on the backside of the nipple.
      Ask FixBot
    3. Large Animal Water Nipple Replacement: step 3, image 1 of 1
      • Pull the mechanism out from the front.
      Ask FixBot
    4. Large Animal Water Nipple Replacement: step 4, image 1 of 1
      • Ensure there is no damage to the hole that needs to be patched.
      • Cracks or fractures are easily made due to sun damage or forcing the mechanism in or out.
      Ask FixBot
    5. Large Animal Water Nipple Replacement: step 5, image 1 of 1
      • Use Teflon tape to line the threads of the new nipple.
      Ask FixBot
    6. Large Animal Water Nipple Replacement: step 6, image 1 of 2 Large Animal Water Nipple Replacement: step 6, image 2 of 2
      • Place the new nipple in the hole with the peg on top.
      Ask FixBot
    7. Large Animal Water Nipple Replacement: step 7, image 1 of 1
      • Fill the container slightly to ensure that there are no leaks. Tighten the washer or pull out to see if a crack has formed while replacing.
      • Tighten the washer to see if that is the source of the leak. If not, pull out to see if a crack has formed while replacing.
      • This is a leak in the seal.
      Ask FixBot
    8. Large Animal Water Nipple Replacement: step 8, image 1 of 1
      • If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
      • Leaking from cracks are easily filled with caulking if the container is small. This would only be a temporary fix on a larger container. Due to the weight of the water, the barrel or bucket would need to be replaced.
      Ask FixBot
    9. Large Animal Water Nipple Replacement: step 9, image 1 of 1
      • Place and thread the nut on the inside of the container on the backside of the nipple.
      Ask FixBot
    10. Large Animal Water Nipple Replacement: step 10, image 1 of 1
      • Finally, place the container in the designated place and fill completely.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 83
All Time: 773
